ILGINC BI TROUBLESHOPS
08.05.2020 21:00 # 1
Emrekkr
206 hdi my diesel vehicle is starting mars but it doesn't work when it starts to spray or hit the lining
It stops immediately when it starts and runs, but it waits half an hour or half an hour trip, I do not stop, it does not work, I changed the crank sensor. do you think it can
08.05.2020 21:00 # 2
samet2461
Is there still software in the vehicle? I had software on my old 206 cars that I used, a similar situation happening in the meantime. I had original software updated to the brain, and I had no problems.
08.05.2020 21:00 # 3
Emrekkr
Yes, while I was buying the vehicle, it was a diesel software with 1.4 software in the advertisement. I did not do anything with me now.
08.05.2020 21:00 # 4
samet2461
[QUOTE = Emrekkr] Yes, while I was buying the vehicle, I wrote 1.4 software diesel software, I did not take any action at the moment when the problem of not working the car is fixed.
I made it for 50TL. Now it is 100 TL. When it returned to the original performance decreased, but fuel was halved. The problem of not working also disappeared
08.05.2020 21:00 # 5
Emrekkr
HOW YOUR FAILURE IS COMPLETELY
08.05.2020 21:00 # 6
samet2461
[QUOTE = Emrekkr] HOW TO FULLY FAILURE [/ QUOTE]
My primary concern was to smoke, continue to have injectors built. I didn't know there was software when I bought it. And as you mentioned, starting the car every morning or getting a long starter was sometimes not working. But let's say not very often once a week or my 2 events. It was like this for a year. Then I had the original software installed, 2 years single starter and smoothly
samet2461 2018-08-30 16:36:34
08.05.2020 21:00 # 7
FTH YLMZ
The same problem was the 2005 model 1.4 diesel peugeot 206 in my own car, I traveled a lot, the last peugeot left the service to the special service, they found that the problem was caused by the brain being repaired before, and it was contactless due to shock on the way, the problem was resolved when the brain was repaired.
08.05.2020 21:00 # 8
Emrekkr
ARIZAM COZULDU RAIL PIPE CHANGE WITH RAIL DISCLOSURE THOUSAND TL EXPENSE OUTPUT SUHAN BI NO TROUBLE
