Ignition System ...
08.05.2020 15:42 # 1
IGNITION SYSTEM
Friends, I Find and Share This Information For You Please Read In Detail ...
Some important parts of the ignition system of the gasoline engine are:
Battery, ignition switch, induction coil, distributor, spark plug and sinker set in the distibrator, low high voltage cables are capacitor, distribution pulley.
The task of the spark plug in glandular engines is to provide ignition. The most important duties of the distributor in gasoline engines are to distribute high voltage from the induction coil to the spark plugs, as well as to ensure the formation of high voltage with the help of platinum and mainsy, and also to distribute electricity with its dispensing pulley.
The induction coil increases the voltage from the battery to 15,000 - 25,000 volts.
It is the distributor that distributes current to the blades according to the firing time. When the engine is not running, the ignition key can be ignored if ignition is turned on in the ignition state or the coil may burn.
Some parts of the vehicle must be replaced after a certain km. One of them is platinum and plug. One of the ignition system settings is the spark plug adjustment and the other is the platinum adjustment and the advance adjustment.
If a platinum nozzle has been made, the condenser may burn. If it makes platinum nozzle, it is cleaned with sandpaper.
If the engine is jerky, it may be because one of the spark plug wires has been disconnected.
One of the reasons why there is no normal burning in a gasoline engine is that spark plugs do not operate normally.
Another one is that the platinum setting is bad and spark plugs are connected to the soot.
If the bushings are not adjusted or worn then the engine loses power.
Exhaust fumes of a vehicle with incorrect spark plug settings are black.
In case of black smoke coming out of the engine exhaust, the mixing ratio should also be checked.
Source: Auto market
the albaydemirc 2011-06-25 12:22:49
08.05.2020 15:42 # 2
Thanks.
08.05.2020 15:42 # 3
Thanks for the helpful sharing, Colonel.
