Ignition cut-off and misfire
19.06.2022 09:45 # 1
YcsTR
Hello. it wasn't there, 5 minutes later the car starts but it didn't start. I called the electrician, he said connect the 2 white wires coming from the black and red box next to the brain, and I connected it, I think it worked, I think it was straight. I wanted to try it somehow, it works without connecting straight for now. Can you help me? What is the reason for this problem ?
20.06.2022 09:21 # 2
The problem seems to be in the engine brain, sir. It cuts off the power from the contact.
20.06.2022 11:56 # 3
YcsTR
Thank you for the answer. Do you mind if I continue to use it with a flat connection for now? I'll do it when the financial situation improves.
21.06.2022 14:55 # 4
I don't think it will be a problem, but be careful, if you make a short circuit or something, it will be a problem.
22.06.2022 17:36 # 5
YcsTR
Thank you for your answers. I'm going to the brainchild as soon as possible.
