IF YOU WANT TO TAKE HKS, YOU WILL HELP? |
| 08.05.2020 15:00 | # 1 |
| 08.05.2020 15:00 | # 2 |
hks not my brand air filter, blow off, what do you want my turbocharger?
| 08.05.2020 15:00 | # 3 |
gokayy |
[QUOTE = dukenukem82] hks not my brand air filter, blow off, what do you want my turbo? [/ QUOTE] |
| 08.05.2020 15:00 | # 4 |
blow off. Because the vehicle is diesel, it is already a turbo ... hks a good brand ... some vehicles are assembled in accessory shops ...
| 08.05.2020 15:00 | # 5 |
what is blow off, what does my teacher do? & nbsp;
| 08.05.2020 15:00 | # 6 |
gokayy |
In turbocharged cars, the part produced to keep the turbo cold air pressure at a high level is called dump valve or blow-off valve. Since the air pressed by the turbo cannot go to the engine, it gets stuck in the snail. The pressure of the trapped gas slows down as it puts pressure on the impeller, and when the gear is shifted and pressed to the gas again, there is a loss of time and serious performance loss so that the pressure of the turbo can return to the top point. Blow-off takes part in throwing the formed pressure out of the snail. |
| 08.05.2020 15:00 | # 7 |
Thank you very much, now for the detailed explanation of the skateboarding.
| 08.05.2020 15:00 | # 8 |
gokayy |
it doesn't matter always :))
| 08.05.2020 15:00 | # 9 |
at the same time, it makes this chit-dice sound. While the engine is running, the pressurized air inside the turbo is released out by hurting while the foot is pulled out of the gas. Here's the fissss sound output from this ... its full name is "blow off valve" ... |
| 08.05.2020 15:00 | # 10 |
I told him that hks is a brand, he laughs at me. D: I was wondering what he meant when I said he would take a hks. Assuming friend replies.
| 08.05.2020 15:00 | # 11 |
pardon friends, I thought you could not write clearly, I thought you would like to have blow off valve of course :) I searched the prices, hks brand 250 lira monza 175 lira which sounds better we work without failure?
| 08.05.2020 15:00 | # 12 |
Thank you guys or you have been very helpful, you haven't even written a cwp ... |
| 08.05.2020 15:00 | # 13 |
gokayy |
[QUOTE = xdesign 206] Thank you guys or you have been very helpful, you didn't even write a cwp ... [/ QUOTE] first of all you asked today, it means that you have made it while standing still after 8 hours. I'd appreciate it if you take care see thanks thank you thank you, not cwp reply & nbsp;
| 08.05.2020 15:00 | # 14 |
Hks, of course, it will be more smooth and late
| 08.05.2020 15:00 | # 15 |
Turkish is very normal, I used the abbreviation there is nothing to be understood, nobody understands the blow off valve. / P> |
| 08.05.2020 15:00 | # 16 |
gokayy |
Then, don't waste it here, my friend, there is no letter in Turkish.
| 08.05.2020 15:00 | # 17 |
I write what I want, my friend can not interfere in the servant of a god ...
| 08.05.2020 15:00 | # 18 |
I write whatever I want, my friend throws & nbsp; I do whatever I do, but I go by car .. & nbsp;
| 08.05.2020 15:00 | # 19 |
You can't write what you want, my friend, this is the forum, and I'm sure there are rules that you don't need to read Most of the people here pay attention to your great style
| 08.05.2020 15:00 | # 20 |
kabusizmit |
[QUOTE = xdesign 206] I write what I want my friend can not interfere in the servant of a god ... [/ QUOTE] How can my friend be a little respectful this forum, this forum has been opened for people to share their information so you can not write whatever you want, you may not get answers to every question you ask. ... & nbsp; When it comes to the problem, you can assemble it in your vehicle here in Istanbul & nbsp; `` Megachip '' Dudullu Kadosan industrial site.HKS is a good brand, do not prefer brands that have not proven themselves. .. |
