IF YOU DO NOT HAVE THE CABLE FROM THE AMP TO THE DOOR SPEAKER.
08.05.2020 16:51 # 1
tayfur
I couldn't fit it in the title, but this is what I want to ask, I bought all the equipment to install plumbing, went to me near the assembly for mounting. ( the original cables that go to the doors. )
The tool I want to learn is that the cables that go to the doors do not get thin, do not pull the thick cable directly from the amp. the installer said, but I couldn't trust it. I did not install.
I understand that the quality of the cable is important, I do not understand, would it be a loss of sound to install in this way. pioneer ts-e170 ci http://www.pioneer.eu/tr/products/25/131/201/TS-E170Ci/specs.html
I have a problem like this, there are no tiweeters in mid team burned I will install a different tiweeter instead. What would you suggest?
08.05.2020 16:51 # 2
hsnsnl
My teacher, you have to use the original cables, if you say why, when I open the door, I think there is a place where the cables go by. I think it is a problem to collect them in pain. You can use them if you do not make them change. I am satisfied with the sound.
08.05.2020 16:51 # 3
tayfur
well as & tbseter & nbsp; Any model I buy will fit my stomachs.
08.05.2020 16:51 # 4
Alicilik
the thinner the wire, the greater the resistance. Excessive resistance lowers the sound quality. It causes overheating. In the future, it can make you not be able to get out of it.
Since I thought about the quality, I pulled a cable with a 1.5 mm copper ratio to my own installation on 4 doors. It is very troublesome to do this. Not everyone is bothered.
Now I am comfortable. It will be my advice to you. Cables in the car's audio system are thicker and higher quality than others, but still cannot replace cables used in audio systems.
If you can, choose new products. If you have this, please say. Search for a product that is close to the original product.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
