if we didn't |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 16:30 | # 1 |
GiTaRRa |
| 08.05.2020 16:30 | # 2 |
kudret_yildirim |
The transmission is not at the bottom, right next to the engine, both in the same place in the engine pool.
| 08.05.2020 16:30 | # 3 |
Can you give some more details. |
| 08.05.2020 16:30 | # 4 |
GiTaRRa |
detail is like a sound under the hood on the front left side of the vehicle, which is more pronounced in cold weather.
| 08.05.2020 16:30 | # 5 |
I just have to press the clutch to this sound.
| 08.05.2020 16:30 | # 6 |
GiTaRRa |
yes it only comes to press on the clutch. Even when the car is idle, it sounds the same. When I pull my foot from the gas, it sounds like a vugg rubbing sound.
| 08.05.2020 16:30 | # 7 |
Let's say the vehicle is running idle. You press the clutch, it sounds, you leave it, the sound is cut off. If this is the case, there is a problem with the ball.
| 08.05.2020 16:30 | # 8 |
GiTaRRa |
the same sound is coming from the clutch when the vehicle is standing while walking, I think you're talking about the clutch ball ..
| 08.05.2020 16:30 | # 9 |
kaan__ |
You get the clearest answer on Tuesday |
| 08.05.2020 16:30 | # 10 |
yes clutch ball.Pressure that will change the gearbox will be removed and the ball will be removed. width = "17" border = "0" alt = "Wink" title = "Wink" />
| 08.05.2020 16:30 | # 11 |
GiTaRRa |
I will get the clearest answer on Tuesday if my friend can not find a room he will eat his head hee: D I hope you find the master .. < / div>
| 08.05.2020 16:30 | # 12 |
[QUOTE = kaan __] you get the clearest answer on Tuesday We only guess here we run, neither see the car nor the malfunction. Just write what might be based on our experience. The best decision is to test the vehicle and examine it closely.
| 08.05.2020 16:30 | # 13 |
GiTaRRa |
[QUOTE = yavuz25] yes clutch ball. To change it, the gearbox will be removed and the ball will be removed and the ball will be removed. height = "17" width = "17" border = "0" alt = "Wink" title = "Wink" /> [/ QUOTE] hmm buddy i guess i am on tuesday as if what you said is logical, i am going to fix it in the morning anyway: D
| 08.05.2020 16:30 | # 14 |
kaan__ |
resolverizzzz distress yooook & nbsp; |
| 08.05.2020 16:30 | # 15 |
My fellow, first of all, get well soon. I know it is very, very likely to be a clutch ball, because it happened to me about 2 months ago. With each passing day, the sound will increase, and if you press the clutch with a strange sound like mouse squeaking, you will change the ball, if you feel like something is rubbing and you feel like vibration. Of course, when the ball is scattered, the pad will wear out, so the trustee will change as a complete set. According to the quality of the product used and the mercy of the master, it has a cost of 350-450 TL. I had a brand of 400 TL.
| 08.05.2020 16:30 | # 16 |
Did the good brand originally have a valeo?
