If the subject is wrong, forgive my emergency help ca
08.05.2020 18:34 # 1
vizyon sound
Friends, I stopped my car in the morning, it is not working in the morning. It is called the brain.
08.05.2020 18:34 # 2
Burak
They usually say battery, but have you checked your battery and tried to hit the vehicle?
08.05.2020 18:34 # 3
DeRyCK
the alternator may also be impaired.
08.05.2020 18:34 # 4
vizyon sound
Friends press the starter, spin the engine but it doesn't work as if there is no gasoline.
08.05.2020 18:34 # 5
herry
Try to operate with the spare key, there may be some trouble in the jeep.
08.05.2020 18:34 # 6
Serkan
It can be an immobilizer or gas pump.
08.05.2020 18:34 # 7
vizyon sound
Friends are not called a spare key, they are called the brain, they said they gave a lot of trouble in the 307s.
08.05.2020 18:34 # 8
vizyon sound
Unfortunately, we tested the gas pump, but unfortunately ..
08.05.2020 18:34 # 9
rolandgarros
Is the teacher a car lpg?
08.05.2020 18:34 # 10
TaZ
dude, do you have music in your car? If you have a (+) cable to pull the petrol pump from industry to the repairman, it will work like you said, yes, you can run your car temporarily as I said, but as you say, you can run your car temporarily from the brain of your brain.
08.05.2020 18:34 # 11
vizyon sound
My gas pump is running, if it is gasoline, it is going to gas.
08.05.2020 18:34 # 12
pusutr
Could the key have fallen to the ground? There may be a problem with the immobilizer chip. Or it may have come out of its socket.
A small possibility is to remove and install the battery terminals for 2 minutes in accordance with the rules. Try it like that.
I don't think there is another problem as far as you explain.
08.05.2020 18:34 # 13
vizyon sound
Thank you all for your friends.
08.05.2020 18:34 # 14
serkomser
[QUOTE = vision sound] Thanks for your friends, thank you all. God bless you too [/ QUOTE]
Can you elaborate a little more? I never understood anything. By the way, get well soon.
08.05.2020 18:34 # 15
muro_60
No, my dear, your brain is broken 307s are always like this ... the people whose mouths are accustomed have failed so much. :))
08.05.2020 18:34 # 16
vizyon sound
Exactly ... if you see the conversations, I did not tell you 307 problem, I did not tell you that you would buy mibgolf, you would enjoy it, no you do not like it. did we buy gasoline or not, I said it is not the pressure that I want again, he said samandra, put on the ring size, 2 rubber orling is called, change the bass, he said, "I'm glad,"
