If the engine comes out during gear shift while it is cold
08.05.2020 14:01 # 1
Emin
Hello friends.
There is a problem in my vehicle, when I start new, when I get the gear from 1 to 2, there is a sound called guuurrrrcccc, but when I switch from 2 to 3, the same sound does not come out. or an idea of where the problem might be.
Vehicle 106 quik.
08.05.2020 14:01 # 2
sinan-s
It is sure that there is a problem with the 2nd gear gear.
08.05.2020 14:01 # 3
GokhaN
I have the same problem. Thumbs Up
08.05.2020 14:01 # 4
Emin
[QUOTE = GKN] there is the same problem with me, nothing will happen Thumbs Up [/ QUOTE]
LOLLOLLOLLOL
08.05.2020 14:01 # 5
hasimayaz
It is normal in the cold. It is difficult to shift into small gears. It is like this in almost all cars. There are additives for cold weather. Change the gearbox oil and print an additive at the top.
You already know about the transmission from the state of the waste oil. If there is metal powder, there may be some problems in the future.
hasimayaz 2009-02-02 12:48:53
08.05.2020 14:01 # 6
haruncoskun
If you are using synchromesh or long clutch wire, I suggest you to install the vts wire, you can adjust the hardness you want, softness or grip from the bottom up, you can also adjust the incontinence problems.
08.05.2020 14:01 # 7
Emin
Thank you Haşim and harun.
Let's show what they will say.
