if I use stylish stylish sound and 10w60 oil_ |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 17:35 | # 1 |
Aziz |
| 08.05.2020 17:35 | # 2 |
_semihk_ |
can be taken care of, my dear teacher .. we only use 10w60 on the tractor .. it is a very thick oil and 10w60 does not have synthetic ones, i know this is dez advantage .. & nbsp; this problem with a friend & nbsp ; http://shop.wurth.com.tr/motor -ic-cleansing-400ml & nbsp; we took care of this product completely .. for a long time the sound hasn't come back again
| 08.05.2020 17:35 | # 3 |
I had that voice, I changed the thrusters, it feels like it is still going on, there is no problem with fuel in the traction. but once it got cold I put the car on sale
| 08.05.2020 17:35 | # 4 |
gokha_nn |
I lived it, he used to worry about 10 40 years later, after the oil was examined, Iıçlıer made full sound, he made the sound turbo b 106 106 user put it with my brother's 10 10 60, I did not say what is thinning, there is a sound, I am satisfied. br>
| 08.05.2020 17:35 | # 5 |
Aziz |
[QUOTE = _semihk_] can be taken care of, my dear teacher .. we only use 10w60 on the tractor .. it is a very thick oil and 10w60 does not have a synthetic die i know this is a disadvantage .. & nbsp; this problem with a friend & nbsp; http: //shop.wurth. com.tr/motor-ic-temizleme-400ml & nbsp; we took care of it completely using this product .. the sound hasn't been coming for a long time again [/ QUOTE] Thank you for the information. I'm going to apply this product to this day, I'm very bored, and in the comment below, he says 106 gti in a friend named gokan_nn and I'm using 10w60, now if I go and clean it with the product, put 10w60? [/ QUOTE] |
| 08.05.2020 17:35 | # 6 |
_semihk_ |
[QUOTE = Aziz] Thank you for the information. I am going to apply this product today, I am very bored, and in the comment below, gokan_nn has 106 gti in the friend named and I use 10w60, now if I go and clean it with the product, put 10w60? [/ QUOTE] < br> the most logical one looks like this .. i think that only non-synthetic oils (of course) are exhausting the vehicle especially when the change time is near. 5w30 or maximum 10w40 I used semi-synthetic oil.
| 08.05.2020 17:35 | # 7 |
Aziz |
[QUOTE = _semihk_] [QUOTE = Aziz] & lt; span style = "line-height: 1.4;" & gt; Thank you for the info. I'm going to apply this product to this day, I am very bored, also in the comment below says 106 gti in gokan_nn friend and I use 10w60, now if I go and clean it with the product, put 10w60? & lt; / span & gt; [/ QUOTE] looks like the most logical one looks like this .. I think that only non-synthetic oils (of course) are tiring the vehicle very much, especially when the time for change approaches. Div > I would use 5w30 or no more than 10w40 semi-synthetic oil [/ QUOTE] I changed the master in Busefer industry, we applied the oil wurdun product, then we used 10w60 mobil 1 oil no sound In the meantime, there will be a 2nd oil change in 1 month :) |
| 08.05.2020 17:35 | # 8 |
I know that they put 10 60 on cars that burn fat because they are usually thick. Most likely it will cut the sound, but I need to investigate thoroughly, hopefully it will solve your problem.
| 08.05.2020 17:35 | # 9 |
Aziz |
[QUOTE = 307bursa] When I say 10w60, do not hurt, do not hurt, master, I know that the oil is very thick and not synthetic, did you investigate this work? [/ QUOTE] On the site, there is a long use of 106 liters, and there is a great change in the sound of the vehicle. I think it stopped, when I pause :)) Now it is like I have left the job with your comment, tomorrow, the cone will be broken. It will probably cut off the sound, but I need to investigate thoroughly, hopefully it will solve your trouble. [/ QUOTE] I hope :)) |
| 08.05.2020 17:35 | # 10 |
Ahmet_ach |
I would recommend the mobile 10 60 oil I have 106 quik 5000 km once castrol magnetic 10 40 I put + boron additive car 5000 km later oil lamp lit oil over oil thickened clotted now 10 60 mobile I put the car monster became quieter than before, if it was more serial If you are going to make a contribution, do not take it off, it just does not work in old cars, our oils are already fully synthetic |
| 08.05.2020 17:35 | # 11 |
Never add additives to the engine oil. Do not rely on this kind of stuff that is bored. |
| 08.05.2020 17:35 | # 12 |
Aziz |
The tail of the calf this morning :) |
| 08.05.2020 17:35 | # 13 |
I'm glad you're done |
| 08.05.2020 17:35 | # 14 |
maestro |
I'm glad that [QUOTE = elsoberano] has resolved
