If I remove the battery terminals of my 307 peugeot car |
| 08.05.2020 19:48 | # 1 |
My friends 307 peugeot 2006 lpg car has 205/55 R 16 rim tires with 4 wheel bolts and I have 4 encrypted wheel bolts in total, one of these 4 wheel bolts. Now my question is that I went to one of the last mechanic, the guy was going to change the rot head, the black pistol broke up with a pneumatic gun, he passed the pistol in the cipher without having to say that he had encrypted it, he forced him to put the encrypted key purple, he broke the nails of the encrypted key, then he tried to disassemble the encrypted bolt with a normal key, then broke the tip ... I replied that you should have it made from the factory in France. Anyway, I would go to the turner and take a tailstock, remove the coded bolts with gas, and replace it with a normal wheel bolt. It is my problem. The current that the brain system withstands maximum is 75 amps. What should I do if I remove the battery heads, the brain will not be damaged, will it not delete some of its functions from memory? If anyone knows, I would be glad if you helped.
| 08.05.2020 19:48 | # 2 |
ARDADOGAN |
I know that it is enough for you to set up your friend and make your head. When welding works on dump trucks, it makes the same system.
| 08.05.2020 19:48 | # 3 |
betaser |
Hello, when the hood of the vehicle is open, mass your doors and windows, after the BSI brain has fallen asleep (Max 20-30sec), remove the poles and assure both the + and - the poles to get a guarantee. no.
| 08.05.2020 19:48 | # 4 |
Now, I was coming from the lathe man, even if he was not aware of him, hammer welding machine will be electro electro mask mask. I removed the encrypted ones, installed a new wheel bolt, then put on the battery, turned the ignition on a level, turned the headlights on first, then started the engine, the result was not just changing the clock setting, but also handling it.
| 08.05.2020 19:49 | # 5 |
ARDADOGAN |
Let's say get well then |
| 08.05.2020 19:49 | # 6 |
Thank you brother, hope you do not encounter such problems. |
