If I don't have an airbag failure
08.05.2020 20:00 # 1
berkant03
Sellam aleykum, dear friends, I said I should put the cruise control
But when I plug it in. The socket just below the fixing arm was dismantled and one resistor was installed.
08.05.2020 20:00 # 2
Just like my brother, the problem set up to extinguish the resistance airbag breakdown light is likely to be repaired between 150-200 TL due to the airbag winding or you will change the com2000 complete last, at zero around 500-600 TL.
08.05.2020 20:00 # 3
AllyDrago
I have an airbag malfunction, or I went to Istanbul, I came to Istanbul on the way back from the broken castle. I don't know what's where and if I say check the wires or something, can you help me, do I have a risk of bidding? If I pull the socket or something, will I open it as an airbag ... ???
08.05.2020 20:00 # 4
[QUOTE = AllyDrago] Airbag malfunction is in me or I went to Istanbul, I came to the road from the broken castle burned by itself. I don't know what's where and if I say check the wires or something, can you help me, do I have a risk of bidding? If I pull the socket or something, will I open it as an airbag ... ??? [/ QUOTE]
No, teacher, the possibility of explosion is that the impact sensor is short-circuited or the impact can be at a certain rate either airbag winding com2000 (headlight wiper arm) problematic. There may be a problem with the underarm sockets. There are sockets under the steering wheel and they may be loosened. the socket under my 206 was loosened when it snapped into place
08.05.2020 20:00 # 5
AllyDrago
Where exactly can you write the place of these cables? driver's seat - under the steering wheel - is there any other? thank you in advance.
08.05.2020 20:00 # 6
[QUOTE = AllyDrago] exactly where would you like to write the location of these cables. driver's seat - under the steering wheel - is there any other? thank you in advance. [/ QUOTE]
My teacher said the piece that comes out when you remove the cover under the steering wheel in the sockets under the steering wheel, holds two screws, allen screws. If you search youtube peugeot 307 com2000 you can see many videos. Thread for armpit sockets
http://forum.peugeotturkey.com/forum_posts.asp?tıd=30872
http://www.peugeotmarket.com/peugeot-307-far-kumanda-kolu-komple-com2000-orjınal,pr-5443.html
08.05.2020 20:00 # 7
berkant03
Dear friends, I solved the incident, I inserted 20 tly myself and checked the connection from the electronics, soldered the broken connection and pulled an extra cable.
08.05.2020 20:00 # 8
Ferhat
Airbag was giving me a winding error, I pulled out com 2000 arm myself, I can help
08.05.2020 20:00 # 9
mbsb44
By the way, my friends are very welcome, my 206 2003 model airbag lamp lights up and gives audible warning twice. The master connected it to the computer, the fault is not visible, I want to change it with a broken signal lever, he said that you will spend 600 liras. I would be glad if you could help friends.
08.05.2020 20:00 # 10
aykutcerit34
[QUOTE = mbsb44] Jove goes very much to my friends, my 206 2003 model airbag lamp lights up and gives audible warning twice. The master connected it to the computer, the fault is not visible, I want to change it with a broken signal lever, he said that you will spend 600 liras. Would you be happy if you help me guys? [/ QUOTE]
The sibling resistor does not troubleshoot, it only gives you the signal of the defective part.
08.05.2020 20:00 # 11
berkant03
Video for you from this address
ready
307 bandage repair Click on the link berkant03 2016-11-19 11:23:14
