idling stop |
| 08.05.2020 15:59 | # 1 |
While waiting at red lights today, the vehicle suddenly stopped. My eyes went to the indicators immediately. but he never did. what do you think is the reason? |
| 08.05.2020 15:59 | # 2 |
g-demir |
needs to repeat several times. it's hard to have an idea this way ...
| 08.05.2020 15:59 | # 3 |
Let's say he did it again. What could be the reason?
| 08.05.2020 15:59 | # 4 |
actual I would appreciate if there are friends or people who have had similar problems. There is no idling fluctuation in my vehicle. But suddenly he stopped as if the electricity was cut off.
| 08.05.2020 15:59 | # 5 |
34sea45 |
it may be from the throttle, because of the butterfly problem of my vehicle, it was fixed when the lights stopped so much in the lights, it could be instantly a problem in the fuel.
| 08.05.2020 15:59 | # 6 |
1-throttle 2-oxygen sensor 3-plugs I think it can happen. I have read other forums, some of the same things have always been caused by these 3. thanks anyway how much are the spark plugs?
| 08.05.2020 15:59 | # 7 |
34sea45 |
varies according to the brand you will get from bosch I would say no wonder 4 of them should be 20 or 30 if I don't remember wrong
| 08.05.2020 15:59 | # 8 |
So, should I adjust the calibration when I have the throat butterfly cleared? In the forum, a topic called “cleaning of the throat butterfly” was opened and they said that there should be a calibration adjustment.
| 08.05.2020 15:59 | # 9 |
[QUOTE = maverick] so do I need to calibrate when I clean the throat butterfly? In the forum, a topic called “cleaning of the throat butterfly” was opened and they said that there should be a calibration adjustment. [/ QUOTE] by the way, the vehicle is not lpg li.
| 08.05.2020 15:59 | # 10 |
mostly happens on idling engine but doesn't do it too often check tachometer fluctuation
| 08.05.2020 15:59 | # 11 |
34sea45 |
I recommend you to make it to the master. |
| 08.05.2020 15:59 | # 12 |
I am on holiday in my country right now. there was a BOSCH CAR SERVICE my father knew. Let them bring my teacher, they said to the device. Can I trust? In addition, a few friends in the forum wrote that the results of bosch's pc connections have different results according to the device connected by the authorized service.
| 08.05.2020 15:59 | # 13 |
34sea45 |
I know that bosch services are successful but after all, it is not certain where it comes from. If you ask me, if you don't keep it for a lot of money, take it and connect it.
| 08.05.2020 15:59 | # 14 |
[QUOTE = maverick] 1-throttle 2-oxygen sensor 3-plugs [/ QUOTE] I agree with these things and I want to add the gas filter. |
| 08.05.2020 15:59 | # 15 |
I got the gas from bp here. After about 20 km, it was like this. I don't understand what the hell are they mixing with water or water. |
| 08.05.2020 15:59 | # 16 |
34sea45 |
If water was added, the sensor in the fuel filter would tell you that there was water in the fuel, it would have burned the light to you.
| 08.05.2020 15:59 | # 17 |
[QUOTE = 34sea45] If water was added, the sensor in the fuel filter would say that there was water in the fuel, it would have burned the light to you. Come on. Look, I didn't know this. Does it give warning if there are foreign additives in gasoline in our cars? Is the STOP light on, bro?
| 08.05.2020 15:59 | # 18 |
34sea45 |
I do not know that much, sorry, but if there are 92 models in 205, this is also based on its logic and I said something like that
