Idling stop
08.05.2020 20:22 # 1
Ekber
Hello friends, I just joined you. I also have a 2003 model lpg pejo 206, usually when the downhill is going down, when I press the clutch to freeze in the bends, it stops on the straight road and sometimes when I press the clutch on the straight road, the car collects very hard. I traveled 20 30 km on gasoline, and I did not encounter the same problem. I made the lpg settings. I wonder why the problem continues?
08.05.2020 20:22 # 2
First of all, welcome to us. The problem was that I found a good LPG master in the LPG system and had to adjust its settings automatically, not manually. I had the same problem on my old Focus 1 car.
08.05.2020 20:22 # 3
semute
most likely lpg system ... lpg idle adjustment should be done again I think there was a piece called butterfly, I think there is a fine adjustment neither too much nor too little should be, the piece may be dirty, it can be changed or cleaned ... an experienced lpg Show your master it won't cost much.
