idling shake
08.05.2020 20:18 # 1
ultraslan22
2004 307 1.6 gasoline xt model vehicle, the car is shaking at idle, it is very tricky, but I am obsessed. it is like nothing changed but they said it was normal to shake so much.
08.05.2020 20:18 # 2
aykutbayram1996
My 206 had tremors, I changed the ears of the engine, and since it presses the chassis, the engine vibrates from the vibration valve setting.
08.05.2020 20:18 # 3
maestro
Can be a spark plug or spark plug coil
08.05.2020 20:18 # 4
By doing sibop, your vehicle automatically adjusts the valve setting with hydraulic pusher. if it is defective, it becomes evident. As our friends say, engine ears and coil and spark plug control should be done.
08.05.2020 20:18 # 5
eymengokhan
teacher, my problem is fixed, my vehicle is doing lpg
08.05.2020 20:18 # 6
eymengokhan
[QUOTE = ultraslan22] 2004 307 1.6 gasoline xt model vehicle, the car is shaking at idle, it makes a little bit of shake but I am obsessed. They connected from the PC and made their settings, nothing changed, but they said it was normal to shake it up.
Sir, have you fixed your problem
