Idling shake
08.05.2020 19:43 # 1
fætih
Friends 307 1.6 xs car is shaking at idle.
The vehicle is more evident in LPG, but the gasoline has the same problem. There is no problem eating gas in gas. only at idle speed, the car trembles fine.
no play at tachometer. There is no agglomeration, shaking, and no frustration as the blast gas is going on the road, but let's come shaking at idle. Did bosch r6 did not bought what spark plug kit. The coil was tried with a solid 307 coil, the room was not the solution. valve failure says master but I said what relevance the car comes out without clicking until the cutter. The issues in the forum are always up in the air. I guess there is no one who can reach a solution. Is there anyone who can solve the same problem?
08.05.2020 19:43 # 2
emreozer1988
I have that same problem. I went to amasya, I came, the voice of the car has changed, it is working with a hoarse voice. I will show it to the master on Saturday.
08.05.2020 19:43 # 3
fætih
no stopping at idle in the car, etc. valve adjustment is a difficult possibility. I suspect motor ears. even if the valve is not costly.
08.05.2020 19:43 # 4
Meanwhile, the valves in your vehicles cannot be adjusted because they have hydraulic thrusters, and they automatically make their own. Throttle cleaning and the idle valve should be checked first.
08.05.2020 19:43 # 5
fætih
There is no valve adjustment for 16v cars.
vvt-i corollada came to our heads.
I do not think it will be from valves. The headlights are brighter when I give the gas to the charge dynamo, because ...
08.05.2020 19:43 # 6
If the battery is new, the dynamo may be troubled.
08.05.2020 19:43 # 7
Ahmet_ach
the engine was getting air from somewhere, or there might be a leak in the air filter tube. I found the problem by spraying water with the experiment.
08.05.2020 19:43 # 8
fætih
The car overheated tonight 85 90 did not do this evening. idling remained constant at 900 rpm. gas adjustment will be done with wide band afr at the weekend. before that, I will clean the idle engine and butterfly. After the settings, I will start the car at idle by means of reinforcement. Greetings to the masters who take our minds as valves ...
08.05.2020 19:43 # 9
palet
Assuming he does not always shiver at idle, I speak;
Do the headlights blink as soon as they flicker at idle? pay attention to it. If there is flickering in the headlight beam, measure the charging voltage as soon as it flickers. If it charges 15 Volts and above at idle and when you make the engine speed like 2000-2500, the charge voltage drops to 14.5 volts and at this moment the flickering of the headlights is lost, the connector is definitely defective.
08.05.2020 19:43 # 10
emreozer1988
When I open the hood and examine it, the sound generally comes from where the air filter, engine cover and lpg injectors are connected. If the problem I will take to the master tomorrow is solved, I will write again from here friends.
08.05.2020 19:43 # 11
fætih
friends how to reset the lft sft values in peugeot Does the battery happen with an external pp2000? I guess the map of the vehicle is broken. I will have to edit the petrol map. I think it will be improved when you drive 100 km.
08.05.2020 19:43 # 12
emreozer1988
Guys, now I came from the master's cause of kicking, master found a hole in the exhaust. A welding area is reserved in the exhaust c ** bowl. He made a connection, there was no sound in the car, no more misfire.
08.05.2020 19:43 # 13
fætih
Hello.
the car continues to shake at idle, but as a biker harun master car in the gardening industry said that number ten is working. valves of the engine, etc. without problems. Since I am tired of the LPG masters now, there is a brother named Murat on the Ispartakule side, and I made the number ten gas setting by synchronizing lfts sft values from the wide band afr device and obd socket. While the vehicle gave a value of 14: 5 at 14: 8 in the gas at full throttle, it initially gave values of 11: 5 at the gas. all my settings are now ten numbers in lpg and gasoline but we couldn't handle idle. The malfunction lamp of the vehicle continues to illuminate but does not illuminate due to neither poor nor rich fuel. We received the bottom o2 sensor heating circuit error. According to the masters, since my last muffler has rotted, it does this when the vehicle cannot be released easily. They said there might be an engine ear. After the order of the friend, the head of the catalytic converter, which I thought of now, was saying that the mouth was bad, it was making me sound, the master was making repairs, but it came to my mind whether he might be missing from there. I guess it would be useful to look at the familiar masters there on Sunday night. I think he was supposed to replace the last muffler.
08.05.2020 19:43 # 14
Yesilkurt
The same problem is in my 307 grandfather, nothing is in gasoline LPG car fluctuates at idling and stops, butterfly throat was cleaned spark plugs changed intake manifold looked air filters changed again the result I did not visit the same veteran no more left LPG's brain ecu water changed 1 day later we reverted in the idle and stopping could not find a malfunction in the same private service
08.05.2020 19:43 # 15
fætih
Mine is not the same as your problem.
my car is just shaking at idle in both petrol and lpg.
no gram fluctuation at idle. the tachometer doesn't even play. whoever says the car is working perfectly. Only the trembling comes inside the room is a little light. I can not comment now that the last muffler has to change the order of God, he had to repair the catalyst and the middle muffler mouth in a change that would have changed vik sound but when I first received it, the gas setting was broken, I did not realize that it was after the repair.
your vehicle is likely to be perfect with a good setting.
http://lpgayar.blogspot.com.tr/
my brother has done this job. There is no equipment lpgcide :)
After tuning, there is no smallest problem with LPG in my vehicle. Rolling over like gasoline does not fall from performance etc. I've been gassing since yesterday: D
fætih 2016-03-27 21:58:07
08.05.2020 19:43 # 16
emreozer1988
friends, have a look at the exhauster. If there is a problem in the exhaust, the car is unbalanced in singing and idling and the vehicle works by singing. There was a lot of trembling in my car and he listened to the sound I took to the master. Nothing in the engine exhaust problem said, they looked at the cause of idle exhaust. The track has changed, the car has improved and it is running smoothly.
08.05.2020 19:43 # 17
emreozer1988
Of course, if the relay kicks off gasoline and LPG, I think the problem is exhaust. But if it is not in gasoline but in LPG, I would say look at the injectors.
