Idling shake
08.05.2020 14:18 # 1
mhakan71
2002 307 xr 1,6 I use 110 hp (lpg + gasoline) while the vehicle is idling (it does not matter in gasoline or lpg) there is a slight jolt, it feels from the inside, there is no play in the idle speed counter, normal,
I visited many masters in Ankara;
Some said engine ears
some said the air suction is dirty
He said that he may have thrown some timers (changed to 5000 km)
They said from the spark plug (I installed 4 new spark plugs)
In short, nobody understands, everyone becomes a master, it does not cause a malfunction when connecting to a PC
they have renewed the engine software again it has not improved
I'm waiting for your help and feedback
Best regards
08.05.2020 14:18 # 2
BuRCaK
I know that this is normal in LPG, but I recommend that you have the idle setting in LPG checked in the service of your LPG kit and have it connected to the computer. The problem with me was solved in my old vehicle.
08.05.2020 14:18 # 3
mhakan71
[QUOTE = BURÇaK] I know that this situation is normal in LPG, but I recommend that you have the idle setting in LPG checked by your LPG kit and have it connected to the computer. The problem with me was solved in my old vehicle. [/ QUOTE]
lpg idling setting is also everything is normal
08.05.2020 14:18 # 4
okankrgz
It is from the oxygen sensor, my friend had the same problem in 206 of the brain, because the brain does not perceive the sensor or not.
08.05.2020 14:18 # 5
Sorry, but I don't agree with "This is normal in LPG". In a properly applied LPG system, there will be no difference from gasoline. There is no jerky operation in LPG. If there is a situation in this way, it says there is a problem in the system. can be resolved and must be resolved. Contrary to what everyone knows, the vehicle is working more smoothly in LPG. This situation comes forward because the lpg octane is higher than the gasoline.
08.05.2020 14:18 # 6
BurcUMUL
fouling in the senator or throttle.
