idling ripple and sometimes stopping |
| 08.05.2020 21:02 | # 1 |
| 08.05.2020 21:02 | # 2 |
Isn't there someone who comes and solves such a problem? My vehicle 2005 1.4 16v XT. |
| 08.05.2020 21:02 | # 3 |
sonerkyl |
First of all, welcome to us. Do you have LPG in the vehicle, hodja?
| 08.05.2020 21:02 | # 4 |
yes there is lpg atiker lined up but it is doing in the lpgdede |
| 08.05.2020 21:02 | # 5 |
[QUOTE = sonerkyl] first of all welcome to us. Do you have LPG in the vehicle, hodja? [/ QUOTE] We're [I'm] glad to be here.. |
| 08.05.2020 21:02 | # 6 |
I can also tell you from the beginning that the throat butterfly has been removed from cleaning. The air pressure sensor has not changed room. |
| 08.05.2020 21:02 | # 7 |
Are you sure that the car is not getting air from anywhere? I had the same situation with the air filters of the throat butterfly.
| 08.05.2020 21:02 | # 8 |
It works with the first gasoline in the in-line system, so the dirt has come down.
| 08.05.2020 21:02 | # 9 |
Peugeot's chronic problem. But it would be solved if you were in Ankara.
| 08.05.2020 21:02 | # 10 |
[QUOTE = Levent ankara 206] Chronicle problem of Peugeot. But it would be solved if you were in Ankara. [/ QUOTE] What is a fuss? Everyone says something to the LPG mechanic and the repairman. If I didn't stop the car, I would say damn it, but I cool it out of the car.
| 08.05.2020 21:02 | # 11 |
The same problem exists in my vehicle. Since LPG is adjusted for gasoline, it is necessary to solve the problem in gasoline first. I couldn't figure it out yet. I will see when my financial situation improves a little. But the mechanic had said that there is a problem with the throat butterfly, it is necessary to change. Not every mechanic knows this problem.
| 08.05.2020 21:02 | # 12 |
I have 106 quik, I bought the car 1 week ago, and I do the same with my Enes brother friend.
| 08.05.2020 21:02 | # 13 |
ykuyucu |
If the map sensor changed what you call the air pressure sensor, there is a problem in its installation. If the single cable is disconnected, it does the same shape. If the vehicle does not stop unplugging while the vehicle is running, check the installation. The problem will be corrected.
| 08.05.2020 21:02 | # 14 |
If you call [QUOTE = ykuyucu] map sensor air pressure sensor, there is a problem in its installation. If the single cable is disconnected, it does the same shape. If the vehicle does not stop unplugging while the vehicle is running, check the installation. The problem will be corrected. [/ QUOTE] I did not understand what I would unplug. The map sensor? |
| 08.05.2020 21:02 | # 15 |
ykuyucu |
yes map sensor
| 08.05.2020 21:02 | # 16 |
[QUOTE = installer] yes map sensor [/ QUOTE] I try. In addition, it makes me react very slowly on the accelerator pedal.
| 08.05.2020 21:02 | # 17 |
We couldn't find a clear solution and started to get angry about this problem. my car is 2007 1.4 16v 307 petrol lpg
| 08.05.2020 21:02 | # 18 |
[QUOTE = lefkefb] We couldn't find a clear solution and started getting nervous about this problem. my car is 2007 1.4 16v 307 petrol lpg [/ QUOTE] I am trying to solve it, I will write here |
| 08.05.2020 21:02 | # 19 |
sonerkyl |
My teacher first of all, if the vehicle is just a little gasoline, 100-200 km idling fluctuation continues or cut off. If it is interrupted, a good lpg setting is required, probably the master has done something about the lpg setting of the vehicle.
| 08.05.2020 21:02 | # 20 |
[QUOTE = sonerkyl] First of all, if the vehicle is a little bit of gasoline, the 100-200 km idle fluctuation continues or cut off. If it is interrupted, a good lpg setting is required, probably the master has done something about the vehicle's lpg setting. [/ QUOTE] I looked at two different LPGs, they said the setting is good. Also doing gasoline lpgdede. The footnote uses the lpgnin system when the vehicle is in gasoline.
