idling ripple
08.05.2020 16:28 # 1
life_answer
friends of a friend's vehicle fluctuates the idle 106 xr room but it did not happen I wanted to consult you & nbsp; I wonder why it could not have been done in the service. ..
08.05.2020 16:28 # 2
Ucyuzalti
What are the rot? S brother "Smile" clean throttle valve, clean idle valve, check ignition system if not passed, replace air filter & nbsp;
08.05.2020 16:28 # 3
life_answer
so it was removed as follows rot rotil sibop as I wrote all of them :) I have no relation :) D
08.05.2020 16:28 # 4
GiTaRRa
look at the idle step by step name is something like a thumb towards the back of the ventilation, take it to the master but say step by step to the idle circuit;)
08.05.2020 16:28 # 5
Ucyuzalti
"Big
08.05.2020 16:28 # 6
Bavik
I totally agree with the "three hundred six" first, clean the throttle, then look at the necessary things with idling, I think it would be enough
08.05.2020 16:28 # 7
aslan7333
did they clean the idle valve?
08.05.2020 16:28 # 8
yavuz25
[QUOTE = Trifold] What are the roles? "Smile" clean throttle valve clean idle valve, check ignition system if it has not passed change filter & nbsp; [/ QUOTE]
is already written by our friend. "Wink"
08.05.2020 16:28 # 9
yavuz25
[QUOTE = aslan7333] did they clean the idle valve? [/ QUOTE]
what is this idle valve like? This is what happens under most things. smiley1.gif "height =" 17 "width =" 17 "border =" 0 "alt =" Smile "title =" Smile "/>
08.05.2020 16:28 # 10
kuzu
THE GAS POTENTIOMETER MAY BE CONNECTED TO THE COMPUTER AND SEE THE POSITION OF THE GAS PEDAL OR THE CANISTER ELECTROVANA MAY NOT WORK PROPERLY.
08.05.2020 16:28 # 11
felusdomesticus
it had been at my 307. The throttle improves when cleaned.
