Idling problem with gasoline when the engine is hot
08.05.2020 21:26 # 1
kursadd
Hello,
2006 Model 206 I have a x-design vehicle. My problem is that in my gasoline & lpg vehicle, the engine is hot, the idle fluctuates and the engine seems choking, but what I don't understand is that everything is normal in the vehicle running on gasoline when the engine is cold. In LPG, everything looks normal when the engine is hot or cold. Why do you think the malfunction is caused by? I do not want to go to the industry right away and have the unnecessary parts of the vehicle tampered with. Thanks.
08.05.2020 21:26 # 2
talip206
If lpg is not a problem at all. If the problem is only with gasoline, there are two possibilities: one is a gas pump and the other is a gasoline injector. The reason why there is no problem when it is cold may be when the idling engine activates and sends a rich mixture to the engine.
08.05.2020 21:26 # 3
kursadd
Thanks for your answer,
Could it be due to the temperature sensor? Since there is no negativity in the temperature indicator, I eliminate this possibility, but what do you think?
kursadd 2020-01-31 10:12:54
08.05.2020 21:26 # 4
talip206
Of course there is a possibility, but I think it would be a problem in LPG.
