Idling problem and stop when switching from gas to LPG
08.05.2020 19:37 # 1
Savask
First of all hello I have been using 2004 mod 307 1.6 xs 3k for about 7 months. I had the Atiker gold kit installed 6 months ago, but for 2 weeks (especially when the engine is cold), it either stops or shifts in the transition from gasoline to LPG, and it continues its operation at the last minute. When I run on gasoline and the engine reaches a certain temperature, manually switching to LPG is not a problem. A few adjustments have been made but my problem continues. I would be happy if someone who has encountered this problem before and got through it or who has knowledge about the topic helps
08.05.2020 19:37 # 2
talip206
The transition from gasoline to LPG is low, elevate it and improve. If you make 45 degrees, there is no problem. Probably your transition temperature is now 30 degrees. In the short term, low lpg heat looks like profit, but it starts to cause huge damage to the engine. It is best to pass two minutes late, but there will be no problems in the future.
08.05.2020 19:37 # 3
Savask
Firstly, thank you
But I did the process you said 2 days ago, and today I encountered this problem 3/4 times a day. I have read a few complaints similar to this problem from right to left but each one writes a different regulator, some injector, and I will show it to the tuner again tomorrow.
08.05.2020 19:37 # 4
Savask
Today, we came to the conclusion that the Atiker `heat sensor` is defective at the 3rd Atiker dealer.
It showed a temperature of 120 degrees, it was worth showering until the 30's attached the robust sensor. When I was given a week for a change, I decided to go to the installation site and the price it gave was 40 TL.
08.05.2020 19:37 # 5
Mesut48
Thanks for writing the result, I'm glad to have the problem resolved :)
08.05.2020 19:37 # 6
risperdal99
I have that same problem. Let us show the heat sensor when the engine is cold while throwing the gas into the gas.
