Idling problem
Homepage » PEUGEOT MODIFIED PLATFORM » 106
08.05.2020 19:48 # 1
medcvt
I have an idle imbalance problem, when my vehicle starts, if I do not load the gas, it stops, this throttle adaptation setting is broken when the battery changes because I did not get infected with my master throttle, I did a price research, I would be glad if you helped the throttle kit 1150 lira ??? medcvt 2016-05-19 22:06:30
08.05.2020 19:48 # 2
It is not necessarily a situation related to the throttle, but the idle sensor crank position sensor can cause this type of malfunction.
25.06.2020 19:41 # 3
106H8333
[QUOTE = medcvt] I have a problem of idling instability my vehicle stops if I do not load the throttle when it first starts, this throttle adaptation setting will be broken when the battery changes because my master said that I do not get into the throttle, I did a price research, the throttle set is 1150 lira what I need to do, I will be glad if you help ??? [/ QUOTE] Did you solve the problem?
