Idling problem
08.05.2020 18:54 # 1
Berat_42
sa friends 97 model 106 gti I have had an irregular speed increase and landing in my car recently, now occasionally I hit the clutch while going through the passage and at normal idling, the idle was correct when I moved up and down the cable of the valve under the idler engine and it became irregular when it was released. I'm waiting for your help thank you ...
08.05.2020 18:54 # 2
Ahmet_ach
throat throttle, this idle chronicle may be a problem in the 106s, idle valve cable sockets may have oxidized, maybe disconnect the cable while the car is running at idle
08.05.2020 18:55 # 3
Berat_42
throat butterfly clean .. okay let me try it again thank you
08.05.2020 18:55 # 4
ekremykk
Teacher, I was in the same trouble, thanks for the friends in the form, they offered me to clean the rotation sensor and the improved tip of the rotation sensor was oxidized.
