Idling problem
08.05.2020 19:47 # 1
Suleyman
I am a new member, I have a problem, I would be glad if you help 2001 model 206 there are idling problems, the car is shaking, sometimes there is no shaking at the first departure less than 10 thousand cycles, but other gears are also no problem.
08.05.2020 19:47 # 2
Cyrus35
There are issues related to the malfunction in the forum, but still a short summary is required.
Causes of vibrating work, idle imbalance ..
* Throat, Butterfly cleaning
* Idling engine failure or cleaning due to pollution
* crank speed sensor
* Pressure sensor (Map sensor) pollution
If all of these causes of failure are at first available, you can clean the socket and the material yourself by cleaning the lining with the lining spray, and you can have it repaired.
* Adaptation is required in case of removal and installation of idler engine cleaning. You can learn by researching the subject.
