Idling Problem
08.05.2020 17:33 # 1
rolandgarros
friends I have idle problems in my 2000 model 206 vehicle occasionally
However, I realized that there is no problem when you are on gasoline, only when I am in the tube, I think it is generally a problem when going up the steep ramp, could it be because the lpg injectors are dirty? the master said that the 2nd and 3rd injectors did not function, do you think I should clean them?
Today, I was repeated again, I was traveling on the ramp, I was traveling at 3000s, although I did not gas it, when the gear was idle, then when I put it in gear and gave it gas, it rose up to 6000-7000. My heart came to my mouth. rolandgarros 2013-05-07 21:15:27
08.05.2020 17:33 # 2
rolandgarros
Does anyone have any suggestions for continuing my problem on slopes?
08.05.2020 17:33 # 3
rolandgarros
08.05.2020 17:33 # 4
Aziz
I understood it a little late, even I still have difficulties to understand, I mean you mean the problem of handover? Is the cycle stuck on the hill at 3000 when you do not supply the gas? Does it do this when shifting down or up? why do you waste while going uphill? I'm still empathizing, but I don't understand, I'm so sorry, I want to help.
08.05.2020 17:33 # 5
rolandgarros
Let me explain that when the road is T at the end of the slope, when I stop the car and disengage it, the tachometer watches in 3000s and the car continues to gas itself. If I wait 2-3 minutes, it returns to normal but it is annoying, it leaves me on the road.
