Idling imbalance
08.05.2020 16:58 # 1
phoenix.1905
& Nbsp; Guys, I don't know how many questions about this idle in this forum, but because of something I did the other day, I started to play an idle, maybe those who know the problem ..
& nbsp; & nbsp;
& nbsp; Idling in my 306 vehicle is under 1000 cycles. However, this does not always happen. 1 week is normal if it works like this for 1 week. Stopping is very rare. Throat butterfly was thoroughly cleaned. & Nbsp;
& nbsp; The other day, while the speed was normal, I went downhill gear 1 to the gas and went down by shouting the vehicle with 5000-6000 revolutions. After this 5-6s landing, I slowed down and the normal hand of the hand started playing unbalanced again. Maybe after 1-2 days it will recover spontaneously, but it annoys the man while using it. I would be glad if those who have an idea share their opinions. & Nbsp;
& nbsp; Thank you .. & nbsp;
08.05.2020 16:58 # 2
There may be several different reasons, but if I were at your place, I would take a look at the toughness of the hotter. Have your vehicle connected to the computer and see if any error code has been generated.
08.05.2020 16:58 # 3
monur
If your throttle has a potentiometer, either there is a problem with your charging dynamo because it does not provide the desired voltage regularly, or the rotating brushes in the throttle are not in full contact.
08.05.2020 16:58 # 4
phoenix.1905
I think it is necessary to connect the vehicle to the computer and see what the error is .. & nbsp; Thank you for your comments ..
08.05.2020 16:58 # 5
ermanglr
Pilgrim problem
It may be 1 throttle.
2 Gas or LPG filter may be clogged
