Idling Fall Stop Problem
08.05.2020 18:50 # 1
themurat54
My vehicle stops falling from idling, it usually happens at the first start. 2007 model 206 sedan tube, I just asked a master, the engine throat will be cleaned, the price varies according to the medicine they use, which he says will cost an average of 70 TL.
Also, if the problem is not from the throat, there are more expensive methods that can help friends with knowledge.
08.05.2020 18:50 # 2
_ali_
If it passes when used in gasoline, LPG may be due to low transition temperature.
08.05.2020 18:50 # 3
toprak83
the throat butterfly with the lining of the lining of the lining around the room 7.5 tl ... whatever you give after the master cleanse dio ... 70 tl what this can be done ... this guy had the same problem in me. ..
08.05.2020 18:50 # 4
ismailkaya
I think your vehicle is drowning if your catalyst exhaust is clogged, you need to have a calibration if you hand it on the throat butterfly.
08.05.2020 18:50 # 5
themurat54
I hope it doesn't hurt much
08.05.2020 18:50 # 6
samet206
Make the idling setting do the same again on the throat butterfly, so its cleaning is not very troublesome, it is cleaned with a lining spray, as the other friend said, but they get 70, 100 or 100 people who do not understand in good faith what it can do.
08.05.2020 18:50 # 7
themurat54
Friends have the engine throat cleaned, I do not know if it is the problem, I have been buying it from the same place since then, there is no instant problem but the cleaning work costed 50 TL, and we are not piled.
08.05.2020 18:50 # 8
Ahmet_ach
they bought a little bit of 50 TL a lot of money to be an industrialist in this period.
If I were in your place, I would buy a torque screwdriver set, Bidet lining spray, these are 20 TL, throat butterfly,
I would remove the idler engine every 6 months and clean it myself ...
08.05.2020 18:50 # 9
themurat54
[QUOTE = Ahmet_ach] bought a little too much 50 TL is a lot of money in this period to be an industrialist, who does not know the job.
I wish I would do it if I do it :) As you said, the guys are doing it, but are they really doing it?
08.05.2020 18:50 # 10
toprak83
I HAVE MADE 20 TL AND SPRAY AT 7.5 TL ...
08.05.2020 18:50 # 11
tetik-soner
Change the idle valve, I had a new one, and it became a monster
08.05.2020 18:50 # 12
themurat54
[QUOTE = trigger-soner] replace idle valve had me too, I installed a new one became a monster [/ QUOTE]
What exactly was your problem, when did you change the idle valve and how long did it cost?
08.05.2020 18:50 # 13
tetik-soner
last year I changed .. original about roughly 180 rubles sub-industry 50-60 rubles ...
stopping while the vehicle was idling ... sometimes stopping while waiting at the lights .. there was a problem like rev counter fluctuation ...
I did the cleaning, the first butterfly did not make a profit, I bought a sub-industry, I got the problem.
08.05.2020 18:50 # 14
sezar206
They said that the 1.4's were either sold or I was going to change the engine. I have no problem stopping. There is no problem in me. the vehicle only works with shaking but I did not know if there was any fluctuation in idling.
08.05.2020 18:50 # 15
aksarayli68
I also have the 1999 model XR, the same problem was happening to me as well, stopping at the lights when it was idle, I explained the situation to the master, he said to me ... he said, the throttle was dirty, he got to be cleaned, he removed it from the air filter, he removed it thoroughly, the pad was cleaned with a spray cleaner, now he works like a monster There is no increase in the vehicle revolutions at 1000 rpm every time ... I bought a spray of 10 lira.
08.05.2020 18:50 # 16
themurat54
[QUOTE = aksarayli68] I also have the 1999 model XR, the same problem was happening with me as well, stopping in the lights when idling, I explained the situation to the master, he said to me ... he said the throttle was dirty, he said it should be cleaned, he removed it from the front of the air filter, he removed it thoroughly and cleaned it with a spray cleaner. now it works like a monster, no idle, no increase in vehicle speed at 1000 rpm at any time ...
Sir, I'm glad for you, but I got it cleaned, but there is still a stop problem. I guess it's usually the first time in the mornings, I think it's a problem with lgp. It is not very extreme, but it bothers people.
In the meantime, was he a car scuba or was he doing the same problem in gasoline?
themurat54 2014-11-28 16:43:12
08.05.2020 18:50 # 17
aksarayli68
[QUOTE = themurat54] [QUOTE = aksarayli68] I also have the 1999 model XR, the same problem was happening to me. When the lights stopped, it was like, I took it to the master, I explained the situation ... he said to me, the throttle was dirty, he said he needed to be cleaned, he removed the front of the air filter, he removed it thoroughly. spray cleaner cleaned and now it works like a monster. At idle, the vehicle speed is not low at 1000 rpm. I bought 10 pounds of spray, I know, winter came, I added an antifreeze to the radiator. I gave it 25 lira. I came. I came. [/ QUOTE]
I did not burn grams of gas after I had it cleaned, I used my car constantly with gasoline. I believe he did it because of the gas
