Idling engine idling adjustment valve
08.05.2020 16:53 # 1
serommm
Friends idling adjustment engine and idling adjustment valve are the same part?
I call idling adjustment engine idling adjustment valve comes out.
My vehicle is delivering gas when it is idle in both gasoline and LPG. When I asked, they said the idle engine will change.
I want to get it now but I don't understand which.
08.05.2020 16:53 # 2
What is a vehicle? Share this information in the signature section so that you do not ask again.
If you have a chassis number, send it back.
08.05.2020 16:53 # 3
serommm
Vehicle 98 306 griffe HB 1.6 engine.
08.05.2020 16:53 # 4
foesarr
This malfunction is also on my 106 quiksilver vehicle. Idle engine replacement is not a solution. my seller is bored of the car. & nbsp;
08.05.2020 16:53 # 5
[QUOTE = serommm] Friends idling adjustment engine and idling adjustment valve is the same part?
My car is delivering gas when it is idle on both gasoline and LPG. When I asked, they said the idling engine will change. div> [/ QUOTE]
I think the same thing that your master meant with you. When the idle valve is called, a complete throat butterfly comes to mind. When you say the engine, only the stepper motor inside can come to mind. Reviews
08.05.2020 16:53 # 6
[QUOTE = foesarr] this malfunction also exists in my 106 quiksilver vehicle. Idle engine replacement is not a solution. my seller is bored of the car. & nbsp; [/ QUOTE]
Your problem may be different. After introducing yourself (link in my signature) you can ask your question under a different title.
08.05.2020 16:53 # 7
sosyete_60
There is a temperature sensor in the engine part, it detects the idle, change it. I had the same problem in me. I changed it.
08.05.2020 16:53 # 8
estair
I had the same problem with my brother when I threw it to the bosses, I gave the gas to himself and I changed the engine of the calligraphy with the 2 mercury attached.
08.05.2020 16:53 # 9
kirmizi306
Did you clean the throttle?
red red306 2012-07-10 11:33:43
08.05.2020 16:53 # 10
serommm
Guys, I didn't understand anything from this job. I have a problem with my peugeot services, crass me.
What peugeot service I called They get the chassis number, there is no part of your vehicle called idle engine, where are they asking me about this part.
Idling They have a sensor that says the throttle is there, but that's not the part I'm looking for.
And the weirdest thing is 430 They gave a million price. Is this melet so expensive? >
08.05.2020 16:53 # 11
serommm
Hello friends today I took the vehicle to a peugeot service in Ankara.
They said there was no problem with the idle engine there was oxidation in the sockets, they sprayed and the car got better, the engine was running jerky, even it was cut.
But just a little time before I come home, the same problem started again. If I renew, I'd be okay.
08.05.2020 16:53 # 12
falan
There are the publishers in Istanbul .. I bought the sponsor sponsor from the site .. I remember 220 TL. they can send by cargo. But before they remove and clean them, if you find a good master, you can get it done.
08.05.2020 16:53 # 13
serommm
Guys, the problem has been resolved.
I don't know how much it has to do, but the water mower was doing it because it was faulty.
Wherever I went They said that the engine will change and they asked for 500 million. >
Do not make your car without asking my friends here without asking a few places.
serommm 2012-07-16 17:38:04
08.05.2020 16:53 # 14
falan
what is the water sensor for the first time i hear ... there is heat sensor or temperature sensor .. water sensor ???
08.05.2020 16:53 # 15
[QUOTE = or something] what is the water sensor for the first time I hear ... there is the heat sensor or the temperature sensor .. the water sensor ??? [/ QUOTE]
The temperature manager.
08.05.2020 16:53 # 16
GiTaRRa
is not stylish, guys ...
problem potentialmeter I had the same problem in me & nbsp; I changed the potential meter, the problem is over.
08.05.2020 16:53 # 17
erden1978
The same problem was with my vehicle. Gas and gas were also stopped when they were wasted. They said idling engine.
The piece value was 550 TL. I did not receive it.
This problem occurred after me in terms of vehicle. When I change the air villa & nbsp; the gas vehicle usually happens in succession. Because LPG doesn't like much air.
There is a wire in the gas wire, setting the idle up. the problem I got was improved. & nbsp;
After that make a Fine gas setting. & nbsp;
08.05.2020 16:53 # 18
serommm
Honestly, my teacher said the water sender, the master, I understand very much, frankly.
They already looked at the computer and looked at it, it looked faulty.
Wrong If I haven't seen the green sender changed.
serommm 2012-07-17 10:18:53
08.05.2020 16:53 # 19
Green color is overheating.
08.05.2020 16:53 # 20
serommm
[QUOTE = laedri] Green color is overheating. [/ QUOTE]
Could be hod. I still do not understand what it has to do.
Anyway, it is the best not to be tampered with more than you do not do anymore :)
Page : / 2
