Idling at Idle
08.05.2020 15:44 # 1
Good night, friends. The 307 1.6 xs is idling in my car and the first take-off (especially on the steering wheel take-off). I guess from the belt, what are your ideas? An important situation? How much does it cost?
08.05.2020 15:44 # 2
An instant squeak or a continuous periodic squeak. Notices from squeak to squeak Gülme
08.05.2020 15:44 # 3
Super squeal in my teacher term Sırıtma
08.05.2020 15:44 # 4
metin
there may be a belt passing through the crank pulley. When turning the steering, the steering pump has difficulty, the current decreases, the flow of the engine rises in the current thought, and then it may rush in the sound.
08.05.2020 15:44 # 5
Muhammet CAKIR
Sırıtma it comes from the belts, I understand that when the car gets hot, it cuts the sound more in the morning: D
08.05.2020 15:44 # 6
Exactly ... the belt is loose. Have a look at the master.
08.05.2020 15:44 # 7
The strap is loose, friends. No problem in balls. It is normal to stretch from the difference of hot and cold weather, said the master.
08.05.2020 15:44 # 8
Muhammet CAKIR
[QUOTE = laedri] Strap loose friends. No problem on balls. It is normal to stretch from the heat-cold weather difference, the master said. Only an important piece, he added that it would hurt his head when it breaks. [/ QUOTE] You take the motor in your hand when it breaks
08.05.2020 15:44 # 9
[QUOTE = Muhammet ÇAKIR] [QUOTE = laedri] The strap has relaxed friends. No problem in the balls. It is normal that he flexes from the difference of hot and cold weather, master added. [/ QUOTE] You get the motor in your hand [/ QUOTE]
Here is my friend, it shouldn't be neglected.
