idling again :(
08.05.2020 15:53 # 1
powerclub206
My friend car p206 xs 1.6 is sometimes too bad in my car. sometimes it gets very high. the dipstick arrives at 90a. sometimes it is 90. When it runs at low speed, it usually gets greedy and stops. When it runs at high speed, it turns up to 1500 times :( I did not complete the tank last week for 1 week. But when the gasoline dropped below the quarter, why did they start again? the albaydemirc 2011-07-25 21:42:38
08.05.2020 15:53 # 2
powerclub206
does anyone know? Shocked
08.05.2020 15:53 # 3
it is a crushing and stabbing thing in me, but my car is a diesel with high probability there is a small hole in the thin diesel pipes.
08.05.2020 15:53 # 4
dukenukem82
Look at you from the gas pump to the throat butterfly :)
08.05.2020 15:53 # 5
onur sahin
Most likely it consists of a throat butterfly. I think you can make a good master clean.
08.05.2020 15:53 # 6
Start by cleaning the throttle first. The source of the problem is likely to be a throttle. Do not enter the engine without doing this operation.
08.05.2020 15:53 # 7
powerclub206
how much is the estimate? Does anyone have any information ?
08.05.2020 15:53 # 8
forewer_fb
I said I was cleaning myself recently. but the engine fault light came on. I connected the pc and deleted the malfunction. after a while it burned again, but this break is dim. I say it was better if I made it to the master :) I guess it costs 30-40 TL
08.05.2020 15:53 # 9
[QUOTE = powerclub206] how much is the forecast? Does anyone know anything? [/ QUOTE]
If you're asking for throttle cleaning, you can do it too. But I don't know much, if you say I will take it to the master, they will get 20TL or something.
08.05.2020 15:53 # 10
hakann83
When cleaning the throttle, be careful to clean it with air without dismantling some of the vehicles are not cleaned, some of them are disassembled and demolished in gasoline, but at that time the problem is getting bigger.
08.05.2020 15:53 # 11
forewer_fb
[QUOTE = Berkay] [QUOTE = powerclub206] how much is the forecast? Does anyone know anything? [/ QUOTE]
I was very careful while cleaning, but the malfunction light went on, I went and gave 20 TL. so I think the master made the same money :))
08.05.2020 15:53 # 12
onur sahin
it is a little expensive if they say it is convenient to clean but it should change. My guess is that after cleaning it, your problem disappears.
08.05.2020 15:53 # 13
powerclub206
I will go to the industry soon. There is also a scarce voice from the front team. it's been a bit too much but sorry Gülme I guess it might be tie rod and tie rod end I'll have it checked.
