Idling after speed
08.05.2020 19:38 # 1
omerszn
Hi guys, if you have any estimates or similar experience about a problem with my vehicle, I would like to know it. I have a Peugeot 206 1.6 Xt vehicle, no lpg. I have no problems in normal use, max. If I use it at 3000-4000 revolutions, but when I load the gas, that is, when I go up to 6000-7000 revolutions, when I slow down again, the speed decreases when I slow down, i.e. it stops when it is going to stop. It stops after fluctuating like this a few times, completely recovering after about 10 minutes. It's been like this for 1.5 years, what could be the reason?
(While the vehicle is stationary, I give as much gas as I want to idle, I even insert it into the breaker, no problem, this problem starts when driving.)
08.05.2020 19:38 # 2
popeyes
Hello Friend, I have a few suggestions,
I strongly recommend that you buy and use 1-injector cleaner. how to use it
helps masters. however, if the injectors are not opened, they may be replaced.
You can replace the 2-speed engine.
It can also be caused by coils without a 3-idle engine. One or more of the coils may have failed.
4- At this point, it may have something to do with the cable in the important throat throttle.
The right part of the throat butterfly is where the plug enters, where oxidation or breakage may have occurred.
08.05.2020 19:38 # 3
omerszn
Thank you, I do not want to take it to the industry without any guess, there are many people who make up their own problems and make extra costs. Based on what you say, I will try to identify it.
08.05.2020 19:38 # 4
popeyes
If you find a master, can you ask about the event I wrote above.
the right part of the throat butterfly is where the plug comes in. Is there any oxidation or breakage? First, take a look at it, at least because it's somewhere under your hand, you can do your job with a dry cleaner.
then, first, use a syringe cleaner is cheap and I think it will work.
then you evaluate the situations.
