Idling 9-10 commutes
08.05.2020 21:19 # 1
kaan206
After starting for the first time in the morning in my 1.6 xs, the idle descends between 9-10, after the car warms up, the idle never plays and remains steady at 9
I am thinking of cleaning the linings spray with the oxygen sensor and the throttle.
No indicator light lit, no problem on traction going
kaan206 2019-09-14 23:01:11
08.05.2020 21:19 # 2
possibly because the parts you call are not cleaned for a long time. got to look and clean. In addition, clean the map sensor. note do you have lpg in the vehicle sonerkyl 2019-09-16 10:46:41
08.05.2020 21:19 # 3
kaan206
I will clean the throttle oxygen sensor at the weekend and check the sockets
There is a lpg, but if I buy gasoline or lpg, it does not cause any change.
I said from LPG
The same situation I run on gas
kaan206 2019-09-16 18:06:32
08.05.2020 21:19 # 4
burkayakc
[QUOTE = kaan206] weekend I will clean the throttle oxygen sensor and check the sockets
I said from LPG
I have the same problem, regardless of gas or gasoline, the car is shaking at idle and plays the tachometer. If anyone knows the solution, please write. or if anyone has a master who can solve it, I would be glad if he says ankara.
burkayakc 2019-09-20 00:43:01
08.05.2020 21:19 # 5
kaan206
I sprayed the lining pad into the throttle and the oxygen sensor and the hole close to 1 liter.
A jet of black liquid flowed from the throttle. I started the car (it works in 1-2 attempts, but we spray it) I gave gas 1-2 minutes of black smoke. Different scents come from the exhaust for 1-2 days. The idling problem has now improved.
08.05.2020 21:19 # 6
x571
[QUOTE = kaan206] I sprayed the lining of the throttle and about 1 liter of lining into the oxygen sensor and hole.
Did you clean it without disassembling it on it? Where is the location of the oxygen sensor
08.05.2020 21:19 # 7
kaan206
I cleaned the throttle without inserting it. Oxygen sensor location 15-20 cm next to the throttle
08.05.2020 21:19 # 8
kaan206
[QUOTE = burkayakc] [QUOTE = kaan206] at the weekend I will clean the throttle oxygen sensor and check the sockets
I said from LPG
You can try what I have applied
Plus 1-2 weeks use the vehicle only on gasoline
Bnm problem disappeared
