Idle vibration and tachometer
08.05.2020 20:41 # 1
206pt
Hello friends, peugeot 206 2005, my model car has shaking at idle and light playing at the rpm. The car is trembling when I stop at red. Playing at the rpm hour. ?
08.05.2020 20:41 # 2
x571
[QUOTE = 206pt] Hello friends, peugeot 206 2005, my model car is shaking at idle and playing lightly at the rpm. did not fix what could be the problem? [/ QUOTE]
can you shoot and put a video?
08.05.2020 20:41 # 3
First of all, welcome, do you have LPG in the vehicle? If there is LPG, use it for a certain period of time, the same problems continue. There may be a problem with the coil. In addition, the catalatic convector may have started to clog. have the last muffler checked.
08.05.2020 20:41 # 4
206pt
Thank you lpg, but it does the same thing in both gasoline and lpg.
08.05.2020 20:41 # 5
sivasli
Hodja, I have the same problem, I don't have gas, gas does not matter, idle does not always matter, hot, cold, I changed the map sensor and idle engine, the computer was adjusted but still the same, now I will have the throttle and oxygen sensors cleaned, I will write here if you find a solution, please share it if you find a solution
08.05.2020 20:41 # 6
bjkamil
Friends I went to the industry for the same trouble on the weekend. As a result of my meeting with a recommended pejo master, he said that these problems are normal in LPG vehicles, and what needs to be done for a solution is to go with 1 tank of gas once a year. He said that the expenses made with other kinds of map sensor, idling engine and throttle cleaning would be wasted. he spoke for sure. I don't know how accurate, but it made sense. I made a gas adjustment, it has improved a bit, now I will go with 1 tank of gasoline and let's try and I will improve in idling :)
08.05.2020 20:41 # 7
sivasli
Hodja, I was already riding with gasoline, the sound is coming from the exhaust, I finally say definitely the throat butterfly.
Because it works smoother in the gas right now, I write the result compared to gasoline
08.05.2020 20:41 # 8
206pt
The throttle valve was provided, the valve adjustment was made in me, I am riding with gasoline, but the result will be the same at the end. 206pt 2017-12-19 19:28:52
08.05.2020 20:41 # 9
sivasli
Well, is there a sound in your car, exhaust in your car? Does the cat cutur sound?
08.05.2020 20:41 # 10
206pt
There is no problem with the exhaust, but when it stops in red or something, the car is silkelio from the bottom.
08.05.2020 20:41 # 11
206pt
What bothers me is that the doors are closed because they are closed, I will sell my car because of this tremor.
08.05.2020 20:41 # 12
sivasli
There are videos about the doors and they can make that sound with tape and sunger. The car stops, the problem gets worse in the traffic
08.05.2020 20:41 # 13
206pt
Hodja, if there is a boshc car service in the place you are, let them look at the service nicely, stop him, make him freak out.
08.05.2020 20:41 # 14
sivasli
I am on the ground but I have never heard of a place like that.
08.05.2020 20:41 # 15
206pt
I am thinking of having the sensors cleaned sockets, but who does the electricians as masters?
08.05.2020 20:41 # 16
206pt
Otohan Akaryakıt Auto Service Sivas
Mehmet Akif Ersoy Mahallesi 30. Sokak No: 6 Yeni Ata Sanayi Sitesi
58000 Sivas
Tel 0 346 211 27 27
Fax 0 346 211 27 27
otohan@boschservice.com.t
08.05.2020 20:41 # 17
sivasli
Thank you very much for your support.
08.05.2020 20:41 # 18
kilic46
My vehicle also had an idle ripple and eventually a stop problem. A hose from the intake manifond to the steering side had come off. I put it in place, it was okay. No master has seen or said. They call it a chronic problem without even opening the hood.
One has to look left and right. Maybe it is getting air and idle gas cannot keep the air setting.
08.05.2020 20:41 # 19
sivasli
I do not understand exactly which cable and where but I hope I look so simple
08.05.2020 20:41 # 20
x571
[QUOTE = bjkamil] Guys I went to industry for the same trouble over the weekend. As a result of my meeting with a recommended pejo master, he said that these problems are normal in LPG vehicles, and what needs to be done for a solution is to go with 1 tank of gas once a year. He said that the expenses made with other kinds of map sensor, idling engine and throttle cleaning would be wasted. he spoke for sure. I don't know how accurate, but it made sense. I made a gas adjustment, it has improved a bit, now I will go with 1 tank of gasoline and let me try it. Will there be improvement in idling:) [/ QUOTE]
they call it the throat butterfly. You call the man gears, let's clear the throat butterfly.
Page : / 3
