Idle unbalanced and stop when wasted (resolved)
08.05.2020 21:25 # 1
Asimlee
My friends vehicle 206 XT 2005 model 16V, I had LPG atiker sequential system 2 months ago and 1 month later idling problem appeared in my vehicle. It fluctuates between 10 and 8, sometimes it does not happen, but often there is play. A week ago, the throttle was cleaned, spark plugs and catalyst changed, the last part of the exhaust rotted yet I have not changed it. He did not stop for 1 week and started to do it again. Usually, when it is wasted, it cannot be collected. Both gasoline and LPG have the same problem. Does anyone know the solution?
Those made:
1-spark plug changed
2-brake pad changed
3- exhaust changed
4- Map sensor cleared
Solution:
1- vehicle p0170 and p0420 (not sure of code, there was catalyst error)
2- When the muffler part of the exhaust changes, p0420 error has ended
3- p0170 already oxygen sensor error
4- Calibration was done in the special service and the problem passed.
a lapse 2020-02-01 20:30:40
08.05.2020 21:25 # 2
ismailkaya
While your vehicle is idling, unplug the oxygen lambda sensors and use it as such and have the sensors check whether they will stop or not.
08.05.2020 21:25 # 3
Asimlee
Thanks I will try and write the result.
08.05.2020 21:25 # 4
Asimlee
By the way, this problem occurs after the vehicle warms up, it is not a problem at the first start and until the temperature indicator rises. I connected the ODBII kit again, the following errors came out; 0170 Fuel Trim (Bank 1) and P0420 Catalyst System Efficiency Below Threshold.
08.05.2020 21:25 # 5
arasemre
Firstly, get well soon. The solution to your problem is to cancel the tube. You will adapt to your vehicle and get on the gas. I haven't heard of 16v vehicles connecting to the tube in a healthy way or solving his pain. The repairers send to the tube maker, send the tube maker to the mechanic, and you will be infamous with your money, and eventually, the tube will be incompatible with this model and get out of the work. The French people say they do not wear waste, but you wear another brand. They cannot shoot a point.
The tubeman who wears that tube also knows and does not say. I have wandered around if I have a recommended master in Izmir. All of them. Enson I canceled the tube, I'm riding on the gasoline. I think it's a weak possibility, but I hope you come across someone to solve your problem.
08.05.2020 21:25 # 6
Asimlee
I got the LPG very recently, even if I operated it, I would like to disassemble about 2 thousand rubles.
08.05.2020 21:25 # 7
talip206
I think the idle engine should be checked. Idle engine on throat butterfly.
08.05.2020 21:25 # 8
omerb
hello problem may not be related to lpg kit. Both fault codes mean the same thing. Oxygen sensors.
You can do the checks done by your friend in the link below. Each vehicle works according to the same logic. When Bank1 opens the oxygen sensor hood, there is an aluminum area. It looks right there.
08.05.2020 21:25 # 9
Asimlee
Friends, today we have connected the computer in the industry, and while deleting the vehicle and the fault codes, we saw that a fault code was not erased, it was giving the brake condition. It turns out that when the brake is applied, the pause stops. The shallow was broken, the problem of stopping when it was changed has improved. For now, there is no problem. But there is a bit of idling ripple problem, it has not been solved completely. Of course, the problem of stopping was a bigger problem for me.
08.05.2020 21:25 # 10
bakar16
have you changed the brake sensor? I have that same problem. rarely stops when clutch + brakes when approaching red light or approaching downhill bumps.
08.05.2020 21:25 # 11
Asimlee
Yes, that was the reason for the engine malfunction lamp to come on. When it changed, the lamp went out, but it does not stop, but the fluctuation of the cycle is in between.
08.05.2020 21:25 # 12
omerb
[QUOTE = Asimlee] Yes, it was already the cause of the engine fault lamp on. When it changed, the lamp went out and it does not stop right now, but the cycle fluctuation is in between.
Is your vehicle automatic gear?
08.05.2020 21:25 # 13
Asimlee
No manual.
08.05.2020 21:25 # 14
RP393
Have the westinghouse control the air from one place engine.
08.05.2020 21:25 # 15
Asimlee
Are you talking about the brake servo?
08.05.2020 21:25 # 16
RP393
[QUOTE = Asimlee] Are you talking about the brake servo? [/ QUOTE]
Yes, in the morning, when the vehicle is cold, the brain sends excess fuel to balance it with excess air, and you do not see any signs of trouble. But there is extra air entering the engine. The reason is either from the westinghouse or lpg connections (holes in the manifold, etc.),
08.05.2020 21:25 # 17
Asimlee
This problem happened 2 weeks after the LPG was installed, so I think there was a problem due to the installation, so I will focus on Probability 2.
08.05.2020 21:25 # 18
Cavusoglum
It is just the opposite in my vehicle .. It only works when the engine is cold and then stops if I do not give gas. If I wait 2 or 3 minutes at 2000 rpm, the engine returns to normal after warming up. The brake stops after a certain period of clutch. It improves after driving 5 6 km. Could it be because of the same things?
08.05.2020 21:25 # 19
Asimlee
Friends problem has occurred again. Apparently there is another problem, it stops again. Topic is up to date
08.05.2020 21:25 # 20
Asimlee
Guys, the problem persists, and tomorrow I will have a special service calibrated. They say what the engine brain intervened and resolved the problem.
Page : / 2
