Idle Surge
18.08.2022 20:23 # 1
goktug34
Greetings friends, do not suggest simple and known solutions Please try it. Throttle tests Ignition system refurbishment Manifold cleaning etc. Everything has been tried.
Sorting the issues
-80 degrees in idle traffic Idle momentarily drops when stopped or at lights (it does this sometimes when steering wheel, but it does when the engine warms up)
-Whether the vehicle is cold or hot, throttle stutter occurs, for example; I give a little gas in traffic, I press the clutch, I look for it to move forward with the acceleration it gets, the vehicle is stuck at 1500 rpm, the vehicle is stuck on the gas, but my foot is not on the gas pedal, I brake, the gas cuts off when I stop the car (does a lot when reversing)
-The speed increases and decreases even though I do not press the gas at the clutch point 1 2 times gasps by itself at the point of grasp
It did it when there was no LPG, it does it when it is gas, it does it with LPG, it does all kinds of things. The engine was newly built, before the top and bottom engine was built, the problem was still there. The ignition of the vehicle is clean, there is no problem, the throttle, etc. has been tried the problem did not pass through any other tool, that is, what every master would say, the things that every person would say were said, ordered, tried, the problem continues, so I am looking for solutions that not everyone knows, because the problem is just that
Vehicle pejo 1.4 engine 307 gasoline (this is 207 group, but the engine systems are the same and this group is more active, maybe it helps)
There seems to be 2 different ways now
1)canister system (gasoline ventilation)
2)pvc system(crankcase ventilation)
A single master has presented these so far, the 1st has been presented, the 2nd one I found while researching the 1st.
Now I have written my problems above, could it be caused by these 2 problems or if there are situations like these that are not known to everyone and cause such an idle problem, I would be very happy if you could share information.
