idle surge
08.05.2020 19:21 # 1
fatihboz
friends do not run out of the day, do not have a problem, one comes before the end, there is a lpg in the car, let me walk in a little gas, fuel is a bit, use a bit, I have red light, the idle suddenly came out from 1 to 3 level, I kept the car difficult, and this situation was repeated twice, today the same problem was similar to the same. . If there was no such thing before in LPG, could there be dirty gasoline left in my car, these questions are due to it :)
08.05.2020 19:21 # 2
sdttn
Idle engine and throttle should be checked.
Connect your vehicle to the diagnostic tool and observe the values.
08.05.2020 19:21 # 3
fatihboz
I wonder if this situation will damage the vehicle.
08.05.2020 19:21 # 4
themurat54
I also have the same problem, it usually feels slightly when I am at LPG while it looks like it. I cleaned the throttle, but it didn't work. I think yours is probably related to idling engine, my weak idea. I guess not
08.05.2020 19:21 # 5
_ali_
Often it is a throat throttle problem, there is idle motor and several electronic sensors on this piece, it is difficult to understand which one is doing this problem.
08.05.2020 19:21 # 6
AliUmut
Friends, I had the same situation.
I would like to take a look at the gas wire together with other friends' solutions.
08.05.2020 19:21 # 7
fatihboz
I think it will be transformed very car today. The car that will stop on the straight road is officially. like 400 500 inputs :)
08.05.2020 19:21 # 8
fatihboz
I just got off the road again and the car started to light up so that the car would not go officially. I parked somewhere, I will go to the master in the morning, the expense of the motor warmer
08.05.2020 19:21 # 9
arachnid
my car engine has been replaced and improved. yours may be that way.
08.05.2020 19:21 # 10
fatihboz
I was a master yesterday 4 spark plug coil and oxygen sensor changed problem
