Idle socket end
08.05.2020 19:40 # 1
ssakyel
Hello friends. I was in the industry for a problem with oil last day. "border =" ">
08.05.2020 19:40 # 2
ssakyel
By the way, the right front wheel. The socket end under the oil filter is empty. It looks like a continuation of the plug inserted in the picture, but it's not.
08.05.2020 19:40 # 3
burakrak53
I think it was like when they moved things up, you take those sockets up, my teacher, it seems like they won't last much from the mud or something
08.05.2020 19:40 # 4
burakrak53
Is there a feature that doesn't work in the meantime? where this cable goes
08.05.2020 19:40 # 5
ssakyel
[QUOTE = burakrak53] Is there a feature that doesn't work in the meantime? where this cable goes [/ QUOTE]
The car does not have an option that does not work outside the tachometer. The car told us something about the fog fog, maybe it might have been put in the socket because it might be fitted in the future. But it could be something else. Let me ask an auto electrician today, what are they?
08.05.2020 19:40 # 6
ssakyel
The electrician did not understand too. Sometimes they can put the socket in idle, he said extra. He said that it is normal to have the other connected there. He said that there is plastic protection under yours. I said good work.
08.05.2020 19:40 # 7
Ahmet_ach
I think the headlight height sounded like a motor socket, look at the headlight height adjustment maybe
08.05.2020 19:40 # 8
samet206
First of all, the fog light socket is a spring-type type and a wider socket as far as I know. There is a warehouse, what else could I not think of, is there a problem with it? I did not get an idle socket in that part before. It is probably related to a feature that is not found in the system infrastructure.
08.05.2020 19:40 # 9
Halil5759
The electrical installations installed on the vehicles in the factory are the same in all packages, for example, while the upper model has abs, esp, fog light, headlight height adjustment, these do not happen in the lower model, but the cables are ready in the installation, my previous vehicle was the 98 model accent sedan, but in the single door models. the wiper assembly was available ....
08.05.2020 19:40 # 10
samet206
For example; there is no 206 wiring, no rear speakers or other things between 99 - 2003 206. There is no electrical wiring related to them, it is rarely seen in some of them. their installations are not exactly the same, they may vary depending on the package and model year.
samet206 2016-02-22 02:12:11
