Idle Sizzling Sound
08.05.2020 20:42 # 1
eran
Friends vehicle 99 models 106 xr automatic at 115,000 km.
While the vehicle is running at idle, it sounds like a deep ciizzzzzzz. So how I say, it's like an electronic voice. It is not heard from inside the car, it is understood when outside. I opened the hood and looked at it, as if it were coming from barriers near the left wheel. It's not a mechanical sound like I said. An electronic device works, sounds a high pitched signal, like it.
Anybody have an idea?
08.05.2020 20:42 # 2
Is there LPG in the vehicle, brother? Is your engine ecu water on the left side?
08.05.2020 20:42 # 3
eran
[QUOTE = sonerkyl] Do you have lpg in the car, brother? Is your engine ecu water on the left side? [/ QUOTE]
No lpg, teacher. I couldn't remember exactly where the medicine was.
08.05.2020 20:42 # 4
So, is there an electric part that is retrofitted like xenon as if it is short circuit?
08.05.2020 20:42 # 5
eran
No, my teacher is completely original. You exactly described it. It sounds like a xenon brain crackling.
08.05.2020 20:42 # 6
Well, look at the headlight engines, brother and sister, start the car and listen.
08.05.2020 20:42 # 7
eran
[QUOTE = sonerkyl] so take a look at the headlights engines, brother and listen to the car. [/ QUOTE]
Sir, the headlights are off while the sound is heard.
08.05.2020 20:42 # 8
It is hard to say without looking at it, my brother may even come from the charging dynamic. or even from the side of Ankara, where are you on brother?
08.05.2020 20:42 # 9
eran
[QUOTE = sonerkyl] It is hard to say without looking at it, brother, maybe it can even come from the charging dynamo. or even the side of Triger, where are you on my brother? [/ QUOTE]
I am on the Eryaman side, sir.
08.05.2020 20:42 # 10
I am on the side of the conqueror, my brother is 10 pm. mobile phone 0505 789 36 33
08.05.2020 20:42 # 11
eran
[QUOTE = sonerkyl] I am on the conqueror side, my brother, like 10 in the evening, let's get together in the wonderland and see if you want. mobile phone 0505 789 36 33 [/ QUOTE]
My teacher would be great and I am on the side of Keçiören right now. It is not clear how many I will return.
I'll show you one tomorrow morning. Can we communicate again according to the result?
08.05.2020 20:42 # 12
talip206
There may be solenoid sizzle. Automatic vehicles have a solenoid sizzle, this is normal. Indicates that solenoids are working. Let someone change gear while you stop to try. In some gears, the sizzle was cut. I don't remember which one.
08.05.2020 20:42 # 13
eran
[QUOTE = talip206] There may be solenoid sizzle. Automatic vehicles have a solenoid sizzle, this is normal. Indicates that solenoids are working. Let someone change gear while you stop to try. In some gears, the sizzle was cut. I don't remember which one. [/ QUOTE]
I stopped by Ankara Vatan Peugeot in the morning. The sound was said to be the steering pump sound, quite normal. What do you think, hodja?
08.05.2020 20:42 # 14
eran
Sir, I asked two different places, there was no problem, the sound of the steering pump and they said as much as it should be.
08.05.2020 20:42 # 15
Okay, brother, it's okay. that is, we can only guess the problems that can happen to us when we are not with the vehicle. Smile
08.05.2020 20:42 # 16
luridline
I'm using 206 Auto. I was skeptical before. I realized there was a solenoid sizzle. I learned that there is something normal. Especially in the last solenoids.
