Idle ripple when turning on the headlights
08.05.2020 20:47 # 1
m.emin58
Hello friends, I have 207 petrol lpg vehicles, 130 thousand thousand lpg or gasoline does not matter, when the headlights are open, the idle fluctuates between 700 and 1200. The engine will be displaced but there is no problem when it goes normally. m.emin58 2018-03-13 19:14:31
08.05.2020 20:47 # 2
ismailkaya
hi mehmet sure first of all, the 1.4 hp motor probably 90 hp engine will not talk like other engines, i will talk very briefly when this engine starts and gives an electrical command in the vehicle, for example, when the lights turn on or turn on the air conditioner, the engine starts out of normal operation and starts working differently. speed, of course, because the lpg brain works with the information it copies first, it cannot keep up with the variable operation of the engine and these problems occur. You will always experience the fluctuation, I don't know if you get the lpg, but 1.4 90 hp gasoline engines do not adapt to normal LPG, but if you use it carefully, I do not think that it will cause trouble when you turn on the lamp or air conditioner. If the light turns on the air conditioner, you will encounter the same problems. The LPG service that did this installation knew this situation and probably should have warned it. This is my personal opinion. There may be those who think differently. I have a vehicle from the same engine. I have been using it for 8 years. I have a normal LPG for a while. I said you know, I did not get it, I still use it in gasoline.
08.05.2020 20:47 # 3
m.emin58
Thank you for your reply, Brother Ismail. Today I cleaned the throttle valve sensor of the vehicle and it was contaminated and someone else said the issue you mentioned. m.emin58 2018-03-13 19:20:12
08.05.2020 20:47 # 4
First of all, welcome to us. the problem is probably related to the lpg system. Sure, brother, did I have an exnon or sound system in the car? You can also check clutch sender. Secondly, it is necessary to check the electrical chassis connections of the vehicle. Battery and charge measurement should also be done.
08.05.2020 20:47 # 5
m.emin58
We are welcome, Hodja. There is nothing extra in the vehicle, whether there is a chassis or not, it is okay, the battery value is also very good. m.emin58 2018-03-13 19:21:29
08.05.2020 20:47 # 6
ben_erhan
I don't know if my friend is going to be troubled. I also had a fluctuation when the vehicle was stopping. Or while turning the steering wheel and taking a turn in the back streets .. I struggled for months. finally it was time for oil maintenance. The problem has improved when the oil of the vehicle has changed.
he hasn't been doing it ever since ... you might say what he has to do with the oil, but it either coincided or was actually due to the oil losing its properties over time ... and measure the battery ..
