Idle Ripple (Video) Help
08.05.2020 20:12 # 1
OguzhanKucuk61
Video 1
Video 2
Idle fluctuation in the first video.
In the second video, it also fluctuates in constant gas.
Is this an important issue?
Small fluctuation during idling has been present for a long time. It was very unobtrusive. Frankly, I don't know what causes it. But the fluctuation seemed strange while delivering constant gas. By the way, I did not observe such a situation while it was stationary in cruise. I'm waiting for your help. Thanks oguzhankucuk61 2017-02-19 01:52:15
08.05.2020 20:12 # 2
talip206
Frankly, I could not see a troubled situation. It seems like it happens when you press the constant throttle because the tremor cannot be fully adjusted with your foot. Which is already difficult to keep milia on the same setting.
08.05.2020 20:12 # 3
dejawu1978
There is no abnormal situation as your friend wants, but as you said, but if you want to convince, clean a throttle
08.05.2020 20:12 # 4
OguzhanKucuk61
[QUOTE = talip206] Frankly I have not seen a troubled situation. It seems like it happens when you press the constant throttle because the tremor cannot be fully adjusted with your foot. Which is already difficult to keep milia on the same setting. [/ QUOTE]
Thanks
Maybe, but I can't play that much. There is definitely a ripple.
So what do you think about the slight fluctuation in the video that I did not gas? Is this a problem?
08.05.2020 20:12 # 5
OguzhanKucuk61
[QUOTE = dejawu1978] the same suitor friend said, there is no abnormal situation ... but if you want to convince, clean a throttle [/ QUOTE]
Does it work, teacher?
08.05.2020 20:12 # 6
dejawu1978
Does it work, teacher? [/ QUOTE]
the gas reaction was late in me, I cleaned the throttle, there was no difference in the late reaction, but it felt like there was an obvious traction difference in the vehicle, but I felt it, but there was a difference, but then I cleaned the oxygen sensor in it, it was defarked in the reaction, of course how much we said it was empty in your own vehicle it would be better to study
unscrew the air filter without removing the throttle as the simplest method. You will see that the black soot is formed from the butterfly. You can clean the lining by spraying the lining but you can find the videos from the net to remove the most beautiful market.
08.05.2020 20:12 # 7
OguzhanKucuk61
Doesn't throttle cleaning want adaptation later, Hojam?
08.05.2020 20:12 # 8
dejawu1978
He wants, but I did not have time for the performance.
08.05.2020 20:12 # 9
ggitaristt
[QUOTE = oguzhankucuk61]
I don't think there will be anything wrong with it, but it is a very hairy situation .
Edit: Also, is the engine hot or cold difference?
ggitaristt 2017-02-19 22:51:12
08.05.2020 20:12 # 10
OguzhanKucuk61
[QUOTE = ggitaristt] [QUOTE = OguzhanKucuk61]
Ripple always exists. The cold engine is at 1000 rpm and the hot engine is around 900. Ripple maximum as seen in video. He doesn't do more and more. Maybe a little less in the hot engine getting up and down.
08.05.2020 20:12 # 11
OguzhanKucuk61
[QUOTE = dejawu1978] wants, but I did not have time for it.
If I leave half, I'm not comfortable, brother now.
I do something incomplete when I take it off, then I get bored.
I show it to a master, I do not have the most, I also have the cleaning and then the adaptation.
But as your guitarist friend says, I don't think there will be much.
But you hit a very bad place;
You said traction, gas reaction.
These are important, let's see.
08.05.2020 20:12 # 12
talip206
If the gas pedal is wired, no adaptation is required. I cleaned the throat butterfly while the vehicle was running. While dismantling the air hose entering the butterfly while the vehicle was running, I sprayed the lining and gave plenty of gas. it blew a lot of white smoke from the exhaust :) then I stopped it after half an hour, it stopped throwing white smoke. He realized the traction. If you are afraid, you can clean and install it without starting the vehicle.
08.05.2020 20:12 # 13
OguzhanKucuk61
I was told it was electric. What is it by the master?
He said something like he made the adjustment, as he was electric, unlike yours. When I asked because of the timely reaction delay.
08.05.2020 20:12 # 14
dejawu1978
Clean the oxygen sensor and throttle and calibrate. you will notice obvious difference in your vehicle .. it has been tried personally (in its uncalibrated form)
08.05.2020 20:12 # 15
KILIC
You can clean the throat butterfly 10-15 TL with lining spray. however, I suggest you go to a mechanic, they calibrate for 50 TL and they clean better. Butterfly cleansing is one of the main causes of idling fluctuation.
08.05.2020 20:12 # 16
samet206
I watched the videos, I think there is no problem to worry about. But you have to test the vehicle, if something is bothering you as a user, the throat butterfly can be cleaned if it has not been done recently, as other friends say.
08.05.2020 20:12 # 17
eu805
my auto 206 had the same problem yesterday, thanks to the master.
08.05.2020 20:12 # 18
OguzhanKucuk61
[QUOTE = samet206] I watched the videos, I think there is no problem to worry about, but I have to test the vehicle, if something is bothering you as a user, the throat butterfly can be cleared if it has not been done recently, as other friends say.
The first reaction of the accelerator and getting it a little late on the slopes was something that bothers me.
I think I can connect it to what I have said. I think an operation will be fine
08.05.2020 20:12 # 19
OguzhanKucuk61
[QUOTE = eu805] my auto 206 had the same problem yesterday, thanks to the master, took care of the sibop settings fixed [/ QUOTE]
Did you just take the action?
Butterfly cleaning or something?
Is there any difference in gas reaction or traction? oguzhankucuk61 2017-02-22 11:02:04
08.05.2020 20:12 # 20
eu805
I went for another problem, the master saw the engine while working, 5-10 seconds, shaking a titrium, I need to adjust the valve, otherwise it consumes a lot of fuel, said today I called the valve setting, it is working properly, now he said, I have not used it yet, I will take it in the evening.
Page : / 2
