Idle Ripple
08.05.2020 21:27 # 1
Asimlee
My friends car 206 XT 1.4 16V 2005 model, I had the problem of stopping in my car, it was lpgli, it stopped when it was wasted, something called calibration was done in the special service and my stop problem was fixed, but they said the catalyst was broken, the oxygen in the OBD II kit was showing the sensor was defective and I changed it code has been deleted. The other error code was p0140 and they deleted it while calibrating. However, after my car warms up, the cycle is experiencing a drop again, I checked all the values in the obd II kit and I add the photo of 02 volts Bank 1 sensor 1 and bank 1 sensor 2 fluctuating too much, what do you think is the reason? Could sensor 2 be faulty ?? In the meantime, there is no problem in the traction of the vehicle, the exhauster said that if the catalyst was defective, the vehicle did not. a lapse 2020-02-07 23:11:33
08.05.2020 21:27 # 2
Asimlee
08.05.2020 21:27 # 3
FatihBall
First of all, the reasons for your vehicle's speed to fall are generally manifold cracks, throttle position sensor malfunction, if your vehicle is at lower speed dead upper speed, your catalyst has completed its life. How often did you change your spark plugs after installing lpg?
08.05.2020 21:27 # 4
Asimlee
After I bought it, I immediately replaced the spark plugs, the throttle was cleared, but the gasoline has the same problem.
08.05.2020 21:27 # 5
FatihBall
then the oxygen sensor is sending incorrect information. Because the sensor that adjusts the air-fuel mixture, check your wiring, and when the oxygen sensor fails, your vehicle's draw will not drop.
You can check it as follows: If dry the vehicle's exhaust does not face the ground, put a piece of cloth that will coincide with the exhaust, heat your engine until the temperature reaches between 70-90. is sending wrong information 05376487053 I will help if the same thing came to the press in golf because the masters do not really want to deal
08.05.2020 21:27 # 6
ismailkaya
How much money did you spend on your vehicle?
08.05.2020 21:27 # 7
Asimlee
A lot of money is gone males3f
08.05.2020 21:27 # 8
Asimlee
The vehicle gave this error today;
08.05.2020 21:27 # 9
bakar16
[QUOTE = lapse A] [/ QUOTE]
According to the graph, there is no abnormal situation. The oxygen sensor sends bumpy data in this way. my problem was that the sudden gas pressure drop and stop approaching the red light.
I suspect my oxygen sensor 2 days ago, I removed it for 1 night (in the light of the information I got from foreign forums), the sensor was broken when I wore it the next day, sending constant 0.1v Cry . I'm going to buy and try a new oxygen sensor today. I also disassembled the coil yesterday, the tires were oxidized, cleaned them, cleaned the throttle and idle engine. I haven't tried yet, I will write the results Thumbs Up
08.05.2020 21:27 # 10
ismailkaya
Oxygen sensors change upper and lower tool original I can not guarantee the very expensive supplier industry I do not use sensors
08.05.2020 21:27 # 11
Asimlee
Is there any harm in not using it?
08.05.2020 21:27 # 12
Asimlee
[QUOTE = looks16] [QUOTE = Asimlee] [/ QUOTE] Looking at the
chart, there is no abnormal oxygen sensor sending bumpy data in this way. my problem was also the problem of a sudden acceleration of gas pressure and stop when approaching the red light. & nbsp;
2 days ago I suspect and disassembled my oxygen sensor. it was constantly sending constant 0.1v "Cry". I'm going to buy and try a new oxygen sensor today. I also disassembled the coil yesterday, the tires were oxidized, cleaned them, cleaned the throttle and idle engine. I'm not trying yet I will write the results "Thumbs
[/ QUOTE] Waiting for the result
08.05.2020 21:27 # 13
muratd
There is also a possibility to do it from the brain ,,, Shaking, kicking, connect to the computer. Brain protects. muratd 2020-02-10 16:43:08
08.05.2020 21:27 # 14
ismailkaya
Enes your engine is running protected, is there any abnormal operation of the engine
08.05.2020 21:27 # 15
Asimlee
[QUOTE = ismailkaya] Enes your engine may be running protected Is there an abnormal operation of the engine
How can I tell if something abnormal is working protected I haven't seen
08.05.2020 21:27 # 16
Asimlee
Did you try?
08.05.2020 21:27 # 17
bakar16
I tried, honestly, I forgot to write here. I opened it as a separate subject.
08.05.2020 21:27 # 18
Asimlee
I couldn't see if you could give a link.
08.05.2020 21:27 # 19
bakar16
here you are: https://forum.peugeotturkey.com/forum_posts.asp?TID=49412&title=vites-bosta-yavasyorum-stop-etme-sorunu-cozumu I did not experience idle fluctuation and stopping
