Idle Hour Hand
08.05.2020 19:24 # 1
yuluseus
Easy come to everyone
The engine top cover gasket replacement has been done because my car has leaked oil into the coolant
After this procedure, it returned to normal, as if it was making too much noise at idle.
When I was idle, the Tachometer needle seemed a little too high to me like in the picture
I don't remember the previous level.
206 2005 Gasoline
08.05.2020 19:24 # 2
teacher valve adjustment done after the change
08.05.2020 19:24 # 3
yuluseus
After the change, it was said to use it for a week, bring it back, but I do not know if it is a valve
A week is running out tomorrow I will take it again tomorrow
08.05.2020 19:24 # 4
My teacher called for the valve adjustment and have the throttle cleaned. it is likely that my teacher will be over 90 degrees in your vehicle intense traffic.
08.05.2020 19:24 # 5
yuluseus
Let me tell you, when the gasket is damaged and engine oil mixes into the coolant, the radiator is blocked by oil. Vehicle temperature hand passed 90 years ago, it was happening in the 90s, because of the summer, unfortunately it was sealed. Now the cooled part does not exceed 80 even in heavy traffic. In addition, instead of cooling water, we threw oil solvent and we will discharge it and put antifreeze.
08.05.2020 19:24 # 6
yuluseus
Valve adjustment was made today. The sound of the engine is better, but the hand of the hand is in the same place.
08.05.2020 19:24 # 7
talip206
My hand is standing in the same place, I think it's the normal place. The temperature is around 90 in the city.
08.05.2020 19:24 # 8
serdaralisan
Teacher, the clock is considered normal, but its main place is the line below 10. There are 3 lines between 0 and 10. All are 3 numbers.
08.05.2020 19:24 # 9
In the line below 10, when the engine is cold, it is 10 in general. My temperature is generally in the line over 90 in the busy traffic for the city.
08.05.2020 19:24 # 10
serdaralisan
your normal teacher is on the line over 90 in heavy traffic, the heat is on when the fan is on line, if you have already noticed it says no problem
08.05.2020 19:24 # 11
My teacher opens and switches between 90 and the line above. Normal traffic in busy traffic is already fixed or slightly below 90.
08.05.2020 19:24 # 12
serdaralisan
ohoo is very nice normal so oh god don't crash it use good bye
08.05.2020 19:24 # 13
If the amen does not cause any accident to Allah, my teacher has just come out of the industry, let us get the job done :)
