Idle fluctuation and difficulty in shifting gears
08.05.2020 21:03 # 1
Ynsbytk
Hello guys, I just joined you first.
I have a 2005 Peugeot 206 panoramic car. I have no problems with the car on short-haul roads, but when I go on a long road, after an average of 1.5, 2 hours, the car acts as if it is switching to serial mode. Normally, the car that shifts at 2,500 rpm starts to shift at 3,500-4,000 rpm. And there are slight idling fluctuations. In urban use, I do not experience any of these problems. I would be happy if someone could inform about this.
08.05.2020 21:03 # 2
First of all, welcome to us. If you are having this problem on a long road, it is a possible heating part or a problem with the parts, teacher. Check for possible coils and spark plugs. Is there a lpg in the vehicle, when was the last maintenance etc. If the transmission oil does not cool down long enough, late replacement of gear changes.
1-As I said, coil spark plug and throttle control for idle ripple.
2-I need to find a good companion master for shaazuman and have a malfunction code with pc. But the first one is to replace the brake sensor, which can often be related to it. It is a cheap piece and make sure it is original.
08.05.2020 21:03 # 3
Ynsbytk
Thank you for the information you provided. I start with cheap parts now artık
08.05.2020 21:03 # 4
First of all, first, use the vehicle in gasoline. Does the fluctuation continue? If it continues after 100-200 km, start from the cheap one, as you say, replace the spark plug and clean the throttle. If gasoline still continues, have the coil and petrol injectors checked.
