Idle fall and fluctuation.
08.05.2020 20:38 # 1
Peugeot35
I have been experiencing the problem of fluctuation and sudden fall in idle for the last 1 week, both in gasoline and gas only when the vehicle is cold, no problem.
Listen to the sound well, there is not much problem in ripple, but I fell for a moment, growling.
It has been 5 months since the maintenance.
oil + oil filter + air filter + spark plug (these have been 5 months since) frankly I suspect the throttle but I don't know if it will do so much.
08.05.2020 20:38 # 2
I think it will be greatly corrected, as if my teacher is caused by the throttle, make it clean and adapt.
08.05.2020 20:38 # 3
maximusti
I have a similar problem recently,
There are frequent fluctuations in idling,
occasionally stops. especially when the temperature is high and stop.
I suspect the throttle.
08.05.2020 20:38 # 4
Cerkesonay
This problem exists in me, lowering of idling, hirlaya hirlaya 30 20 10 stop at LPG, the vehicle stops, stop, get up and when the speed falls in the lights
2000 Model Peugeot 306 1.8 XT
08.05.2020 20:38 # 5
Peugeot35
I think it would be useful to have the throttle in peugeot authorized or special services, but as much as I heard they were cleaning for about 100 TL. it had to be cleaned in the throttle with each oil maintenance.
08.05.2020 20:38 # 6
maximusti
I wonder if anyone can remove this butterfly and clean it?
It doesn't look so hard as far as I can see on the internet,
you remove the air filter first, then you remove the butterfly,
you wash it well with gasoline, polish it and put it back in its place,
but it does adapt to some vehicles, do we do it in our vehicles?
08.05.2020 20:38 # 7
Peugeot35
[QUOTE = maximusti] I wonder if anyone disassembled and cleaned this butterfly?
Disassembling, cleaning is very simple, so now I did the problem adaptation, some vehicles do not want adaptation, but I do not want to take risks or it is more convenient to clean and adapt the service. I did not know.
08.05.2020 20:38 # 8
ismailkaya
I have a 307 2005 model 1.4 gasoline 90 hp vehicle, I am removing and cleaning it myself. sending and opening and closing the valve ratio balances the ratio of fuel and air, in my opinion, idle irregularity catalytic converter signals come out from there butterfly throat only keeps up with these signals you are removing the air filter you have 3 screws holding the butterfly throat, you are removing them, you are removing the electrical cable socket, removing the butterfly throat, clean it, put it back into place NOTE: USE YOUR VEHICLE IN INTERMEDIATE HIGH CIRCUMSTATION OF THE CATALITIC CONVERTER IS NOT PASSING FROM THE EXHAUST EMISSION.
08.05.2020 20:38 # 9
ismailkaya
REMOVE THE BRAKE HYDRAULIC OIL BOX FROM REMOVING THE AIR FILTER AND SHIFT TO THE TOP OF THE BATTERY
08.05.2020 20:38 # 10
Peugeot35
[QUOTE = ismailkaya] 307 2005 model 1.4 I have a 90 hp 90 hp car, I have to remove it and clean it once I wondered and disassembled it completely. sends a motion signal to the engine in its throat and closes the valve proportionally, balances fuel and air ratio, in my opinion, idle irregularity signals related to catalytic converter come out from there butterfly throat just keeps up with these signals you are removing the air filter you are removing 3 screws holding the butterfly throat you are removing them electrical cable socket you are removing the butterfly throat clean it in your hand, put it back in its place
Well, when you disassemble, do you play the moving round disc in it? If I lean wrong, I am talking about the disc in the cleaned area, that is, the disc that the motor moves, and when it is playing by hand, it has to be adapted. I will also try cleaning with what I am cleaning.
I could attend the event you said, I had no idle falls and growl, just idle when it first worked on gasoline was fluctuating for 30 seconds. the setting was improved with more adjustments, but I am having this problem, of course, the light did not burn again and said it was related to the measurement. Normally butterfly cleaning needs to be cleaned at certain intervals. I have been using it for 1 year and I have not done any cleaning. I do not think it did it before me, so my goal is to look at the butterfly.
08.05.2020 20:38 # 11
ismailkaya
I think you have LPG in your vehicle LPG It causes trouble in these vehicles. liquid system lpg is recommended why if you say, if you give an example, you turn on the headlights or operate the air conditioner while using your vehicle in petrol, this engine changes the operating system when you turn on or start the engine, it works differently in every command you make in the vehicle. causing the malfunction light to come on or idle. the round disc that you call plays with hand but plays a little hard. Do not let me clean the belt or timing belt there is oil leakage.
08.05.2020 20:38 # 12
ben_erhan
Guys, I have had the problem of idling ripple for a long time. you can find posts about this topic in the forum ...
Throttle cleaning is of course, whether you do it yourself or make it to a master. It is not a serviceable situation. Adaptation is not required in 307s ... my problem was resolved 3-4 days when I cleaned the throttle but then it started again ... I thought it would be electrical and I overhauled all plug-in plugs in the vehicle. I checked for loose etc etc .. Then I took the area with the harness in the middle by hand, shook it, mixed it :) It may sound funny but when it did not improve for months, I did this and it was fixed ...
First of all, clean the throttle, if it does not improve, I got a lot of help from the friends here, they said it might be a map sensor, I bought a map sensor, it did not improve again, I went to the tube setting, it did not improve again, you do these operations in order ... I even changed the brake sensor ... was to overhaul the sockets. even if you can, clean and dry what you can clean with lining spray.
I hope you get rid of this problem at the time.
08.05.2020 20:38 # 13
Peugeot35
friends, I got a lot of things I had a few shares of it. I cleaned the pad with spray and brush support. I did not leave the slightest stain. As a result, our throttle was like zero if we look at the pictures. my main problem is not resolved.
throttle cleaning was wiped out of mind adaptation setting was carried out. If the saddle is not in the room, it may cause the oxygen sensor had burned the engine lamp. It did not burn after the lpg setting. Adaptation or map sensor or idling motor remains. Currently, the situations are not available and I have to look at them later.
Peugeot35 2017-11-10 20:55:22
08.05.2020 20:38 # 14
Peugeot35
is this true
08.05.2020 20:38 # 15
Peugeot35
today I removed the map sensor, cleaned it, things like the black oil inside the throttle had officially closed the sensor, I cleaned it with a lining spray, I put it back, but the result is over 90 thrush where I stopped, 2 or 3 times. I searched for the map sensor, when we did not see it as a very active thing, we cleared the idle, that is, this caused the grumpy that I talked about, but it did not change anything, maybe it might be corrupted.
08.05.2020 20:38 # 16
Pastoral
I have a 307 SW 1.6 petrol 2003 model car. The problem is that shaking at idle does not always flicker, but more when the engine is warming up. When I press the gas violently, the idle improves, but it can drop again later. When the idle is low, the light intensity of the headlights of the vehicle decreases and increases. In addition, the vehicle fell out of traction, now the slopes have become nightmares for me, I have to load the gas on a light slope, the vehicle is recovering late, the bucks have changed, the butterfly has been removed from the crashed vehicle, nothing has changed, I put my old butterfly back on it, ECU software in the brain part renewed became worse, restore old software defim authorized service failed. Boredom will help you, hopefully friends who have experienced this problem can help.
08.05.2020 20:38 # 17
Peugeot35
[QUOTE = Pastoral] I have 307 SW 1.6 petrol 2003 model car. The problem is that shaking at idle does not always flicker, but more when the engine is warming up. When I press the gas violently, the idle improves, but it can drop again later. When the idle is low, the light intensity of the headlights of the vehicle decreases and increases. In addition, the vehicle fell out of traction, now the slopes have become nightmares for me, I have to load the gas on a light slope, the vehicle is recovering late, the bucks have changed, the butterfly has been removed from the crashed vehicle, nothing has changed, I put my old butterfly back on it, ECU software in the brain part renewed became worse, restore old software defim authorized service failed. Boredom will help you, hopefully friends who have experienced this problem can help.
Remove and clean the map sensor and do the following adaptation event. The course may change. If the spark plugs are not original, the vehicle drops from the traction, it burns, the performance ends. Our 307 spark plugs are of two types. One of them is the spark plug used in the bosch one renault clio 2. My problem was that the idling was fluctuating, I cleaned the butterfly, now the situation I call growling now, the current idle is at a time when the engine is hot, the room is not always always falling off and momentarily, it disappears 2 or 3 times later, I am in my research.
08.05.2020 20:38 # 18
ben_erhan
307 adaptation is automatic .. I bought a map sensor for this event.
08.05.2020 20:38 # 19
Peugeot35
[QUOTE = ben_erhan] 307 adaptation is automatic .. I bought a map sensor for this event.
For which event is a snarling problem? Can you sell the map sensor in your hand? If I try to buy it, it will take a long time to come from China, I think to try it. We cleared the sensor, but I doubt its robustness.
08.05.2020 20:38 # 20
fatihpejo
I have the same problems with my 307 1,4 xr 2005 model car, when the temperature exceeds 80, the fluctuation starts at idling and stops at the red light.
Page : / 3
