Idle engine problem and brain
08.05.2020 21:18 # 1
Murat48
Friends I bought pejo 206 1.6 petrol 2000 model car .. 60 krs at gas and gas at km. Burning. Gas adjustment should be 2.5 milliseconds, ostidem injectors should come out in 11s and they cannot adjust. I am coming from the room, not working, I suspect from the brain ... I bring it to the master, it tells a part of it, I do not trust the masters that will change. I want to have the brain checked if there is a good master. Confused Murat48 2019-08-18 21:43:42
08.05.2020 21:18 # 2
ismailkaya
How do you use this tool if the idle engine is not working? Does the vehicle walk? 60 krş is burning too much, the idle engine does not work at 3 volts and shows that the engine is faulty. the catalyst may be clogged, i.e. the sensors on it have completed their lifespan, and the sensors on it have to be replaced, and their lifetime is complete. have the injectors checked and the spark plugs require an air filter and oil change
08.05.2020 21:18 # 3
If you are on the mainland, there is a Mas Peugeot. one of the abdullah and selcuk us would recommend the mechanic value electric and electronicist.
