Idle Engine Cleaning
08.05.2020 18:04 # 1
tokyo
Hello there,
My vehicle 2005 307 SW. There was a problem with stopping at idle in the tube. I took it to the LPG service, remove the idle engine, clean it and pass it. It was doing when the engine was hot.
I want to disassemble and clean, but where the idle engine is in the engine. Can you help me?
Thanks in advance.
08.05.2020 18:04 # 2
mev347
My vehicle 206 had the same problem in me. The problem of stopping and gasing by itself. I took it to the mechanic, said it would change, idling valve. oil layer flowed through it.I put the valve in place and the result is super.
08.05.2020 18:04 # 3
tokyo
I couldn't find it on the engine, I'll change it if I find it.
08.05.2020 18:04 # 4
mev347
It is a big possibility behind the throat butterfly :)
08.05.2020 18:04 # 5
tokyo
you said I cleaned it, how did you do it ...
08.05.2020 18:04 # 6
mev347
I removed the complete idle valve. I squeezed it out of the long pad lining of the lining.
08.05.2020 18:04 # 7
tokyo
I took it to the master, he looked at the spark plugs, they were all loose, that the previous donkey was not squeezed, I replaced the spark plugs, thank goodness it disappeared. Those who have this problem first say, look at the spark plugs.
08.05.2020 18:04 # 8
muku
mrb friends, my 206 is also gasing constantly, I changed the throat butterfly improved 1 month later the same, the master was idling the engine, what do you think?
08.05.2020 18:04 # 9
tokyo
Mine was stopping, it could be idling engine if it gives gas. Show me a good master, I think.
