Iciyoor Meret with LPG Not Dry Gasoline
08.05.2020 17:05 # 1
Peugeot306
Selamin aleykum Friends Let me write the fuel values of the vehicle You show me a way out
I went to the store, I went 100 km again, I went back to 45 tl It was 100 km
I went 100 km for the second time fulledim 36 tlye is full
I went 100 km for the third time 35 tl is full
Lastly I traveled 180 km 75 liters of gas burned Gazin lt price 2.60 tl
In the sequential system, is it normal for the vehicle that I use at lpg to burn 40 tl of gasoline per month? (In the first run, if we calculate that it runs for 2-3 minutes)
In short, the vehicle is at least 0.36 TL per km. Is it normal? This is subject to change according to time. But this average vehicle is 306 griffe 1.6
Peugeot306 2012-10-12 01:16:42
08.05.2020 17:05 # 2
berk2309
your usage style & nbsp; the gear you change in the city you change too much stop & nbsp; the pressure pad is close to the end, spark plugs are the normal spark plugs or the spark plugs used in lpg & nbsp;
08.05.2020 17:05 # 3
Peugeot306
spark plugs have just replaced the spark plug just like the spark plug, spark plug cable, transmission wedge. The first result I wrote in the city is the second traffic I wrote, the third time I wrote, I did not stop, do not stop too much.
08.05.2020 17:05 # 4
berk2309
Friends using LPG they use spark plugs produced for them. They are much more efficient. According to the result, I think if you go 120 at 100 km, normal burning and & nbsp; warehouse how many leaks. I think that if you say 40 TL in a month, I am using it in gasoline, I think it will help in friends who use high lpg and cig gas at the end of the first morning.
08.05.2020 17:05 # 5
Peugeot306
[QUOTE = berk2309] friends who use lpg are using the spark plugs they have produced for them and they are more productive kadaryla & nbsp; 3. According to the result, I think if you go 120 at 100 km, normal burning and & nbsp; warehouse how many leaks. I think that if you say 40 TL in a month, I am using it in a gasoline. >
Compared to the others, I think that my values are not too high in 90 kmh, I think there is a setback of 36 tl liters per 100 km warehouse 30 lt. 36 kurus more per km
08.05.2020 17:05 # 6
berk2309
The lpg setting can be very obvious, maybe because of it & nbsp;
08.05.2020 17:05 # 7
Peugeot306
I had the ignition coil and spark plugs replaced. I still haven't found the problem. Will it normally burn this vehicle? & Nbsp;
