I yardıııııııııııı
08.05.2020 14:06 # 1
asil 206
friends, 206 m does not work .... in the morning when changing the trunk lamp, I made a chassis, when turning the ignition, the parks are on its own, the starter motor is pressing strong but the car does not work, do you think there is a problem with BIS?
08.05.2020 14:06 # 2
battery is discharged
08.05.2020 14:06 # 3
asil 206
Emrah is unfortunately not a battery ...
08.05.2020 14:06 # 4
asil 206
I took off the poles and waited, but nothing changed
08.05.2020 14:06 # 5
hasimayaz
BSI fuse blown Check all fuses 1 each 20 amp in fuse boxes under cockpit and hood. Insurance will check them.
08.05.2020 14:06 # 6
asil 206
I will look after sacrifice to my brother, sacrifice tomorrow, as you said
08.05.2020 14:06 # 7
asil 206
I checked all of them, unfortunately, all of them are intact, I think the BSI is history, but why the parks are burning when I turn the contact I don't understand .......
08.05.2020 14:06 # 8
haruncoskun
I hope it is not a big problem, get past, but BSI does not burn with making a small chassis & nbsp;
08.05.2020 14:06 # 9
asil 206
that's what I don't understand; but I did not understand why this happened when no fuse was blown
08.05.2020 14:06 # 10
haruncoskun
Where are you from, aceba?
08.05.2020 14:06 # 11
asil 206
BITLIS
08.05.2020 14:06 # 12
haruncoskun
You were away off: S ALLAH make it easy for me, don't leave it to the masters there, show it to the nearest service & nbsp;
08.05.2020 14:06 # 13
asil 206
I THINK SO, I THINK TO TAKE A VAN A .... THANK YOU END OF THIS YEAR
08.05.2020 14:06 # 14
hasimayaz
Have you checked all of the fuses? on the motor side?
com2000 grandpa may have trouble. BSI does not burn easily.
08.05.2020 14:06 # 15
H-a-d-i
I think one of the fuses in a secret place must have blown. There is a lot of insurance to throw until BSI. Listen to Hashim brother, check the fuses well. make it easy ...
08.05.2020 14:06 # 16
peugeotefe
BSI may have reset itself
08.05.2020 14:06 # 17
asil 206
is running .... "Clap" "Clap" " "Clap"
08.05.2020 14:06 # 18
Murat
The same thing happened to me, my brother. I pressed the starter again, but the engine was not running.
I was at the mountain top in Olympos. I called the automobile, they sent the tractor. The car has gone above 220 km tow truck. I went to the service, they spent 50 kurus insurance, 62 liras for me.
Now let me tell you the solution.
Haşim told me, but I will tell you in more detail.
Don't fade 62 TL for 50 kurus insurance. "Cry"
There is a small 20 Amp fuse in the bottom left corner of the fuse box under the steering wheel. It's yellow.
Change it. Your vehicle will be recovered.
That insurance is BSI's insurance. The electrical system of the vehicle is mixed because it fuses. Everything goes together.
The reason why the vehicle does not work is that it does not read IMMO.
It will surely be.
Open the bonnet, I think there is the same fuse in the fuse box on the right side, check it too. >
Get well soon.
08.05.2020 14:06 # 19
asil 206
I was just taking Van to the service that an insurance I missed; 20 apr fuse, which was said by this brother, I realized that he had blown, he worked like a monster when he replaced it with his backup, now the injection lamp is on, I guess it goes out because of drowning in the gas ..... thanks to all the pt who helped, I couldn't have done it without you ...
08.05.2020 14:06 # 20
asil 206
I came here last summer but we couldn't meet, let's meet this summer ... beers from me, but with the condition of returning home with commercial ..
Page : / 2
