I would like your urgent help partner
08.05.2020 21:10 # 1
serknrn
I have a 2004 partner 1.9 air-conditioned diesel vehicle.
Last morning, I will start the car, it does not work. It has battery, electricity, fuel, oil, water but it does not work.
The other master key has a chip, it may be broken, if you turn the key when it breaks, it doesn't send a signal to the brain, naturally the engine can't get the data needed to draw fuel and it won't work.
The same master may have gone in the brain, 600 lira brain, 300 tl key can hold about prices, he said.
I'm waiting for your ideas, my car is waiting at the door, I can't see my strength.
Gokhan 2019-02-28 09:21:38
08.05.2020 21:10 # 2
dijital elektirik
Get well, although the old spark plugs were broken in my old car, they were running smoothly in extreme cold weather so it was running late jerky, so the spark plug would hardly have an immobilizer problem in my mind.
08.05.2020 21:10 # 3
As the probability of having a contact is high, my teacher immo may be damaged or contact thermal may be malfunctioning. The device is controlled with the device in auto keymakers.
08.05.2020 21:10 # 4
27BEN80
immo malfunction go to the unlocking in me, probably the chip has had trouble.
08.05.2020 21:10 # 5
GokhaN
They said they could be able to say the sound of the garment reminds me of the battery in these cold weather.
Afterwards, the starter motor, the brain is the latest immobilizer
08.05.2020 21:10 # 6
serknrn
Thank you guys for the support, I changed the battery of the car key, when replacing, we found the chip dropped, whatever it fell in. We plugged it in and it worked out.
Now our new problem; When it comes to the bumps or pit from the estimated shock absorber around the front wheels, there is a lot of noise coming from the road. Everyone says it is not important. do you have any idea
Also, there are lock problems on my doors, I do not lock from the control, I lock the other doors manually from the driver's door, if you have an opinion about this, I would like your comments.
08.05.2020 21:10 # 7
Falderal06
Sliding doors do not lock?
