|   | I wonder if there is a canister tank vacuum valve problem ... |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 17:30 | # 1 |
|  volkan22 | |
| There is a vacuum in the tank of my car. When I open the gasoline cap, it sounds like a plug, and I inserted the hose from the vacuum valve on the front to the canister. Engine light comes on when the hose between the valve and the canister is attached and a vacuum is created in the tank The hose between the canister and the vacuum valve is inserted and my car freezes to normal. Note: My vehicle sometimes falls on the trailer with the hose attached and the exhaust explodes ... In the Pejo service, the authorized person had opened the inside of the csnist, and then closed it again with silicone. I would appreciate if the vacuum valve can help the valve between the canister and the valve is sucking the valve. | |
