I wonder if anyone came to Brake fluid level low? |
| 08.05.2020 16:32 | # 1 |
| 08.05.2020 16:32 | # 2 |
[QUOTE = erdal_comak] friends I brought a few special services, they couldn't find the solution, I changed the upper oil box again, the same stop lamp is flashing. > abs running and brake oil normal & nbsp;
| 08.05.2020 16:32 | # 3 |
Kemanyak |
Brake oil sensor can be oxidized. Finally, remove the battery terminals. Wait for 3 minutes ... hopefully it will improve.
| 08.05.2020 16:32 | # 4 |
Clean the sockets with wd 40 la then reset as my brother said.
| 08.05.2020 16:32 | # 5 |
djchaos |
wd 40 is collecting excess dirt again, wouldn't it be a problem again? I know how the lining spray can remove rust and dirt
| 08.05.2020 16:32 | # 6 |
[QUOTE = djchaos] wd 40 is collecting excess dirt again, wouldn't it be a problem again? I know how the lining spray has rust and dirt removal feature [/ QUOTE] Lint spray & nbsp; It is used for cleaning lubricated parts. Its main purpose is to clean the brake disc from oils and other lubricants and increase friction. WD 40 is both rust remover and lubricant, meaning it prevents oxidation again while cleaning the rusty surface. /smiley1.gif "border =" 0 "alt =" Smile "title =" Smile "/> & nbsp; I applied it to the battery terminals. It is not necessary to apply grease to the battery pole. |
| 08.05.2020 16:32 | # 7 |
[QUOTE = 06ÖZGÜR06] [QUOTE = djchaos] wd 40 is collecting excess dirt, wouldn't it be a problem again? I know how the lining spray has rust and dirt removal feature [/ QUOTE] Lint spray & nbsp; It is used for cleaning lubricated parts. Its main purpose is to clean the brake disc from oils and other lubricants and increase friction. WD 40 is both rust remover and lubricant, meaning it prevents oxidation again while cleaning the rusty surface. /smiley1.gif "border =" 0 "alt =" Smile "title =" Smile "/> & nbsp; I applied it to the battery terminals. It is unnecessary to apply grease oil per battery pole. [/ QUOTE] bro you grew up before us again.
| 08.05.2020 16:32 | # 8 |
[QUOTE = yavuz25] [QUOTE = 06ÖZGüR06] [QUOTE = djchaos] wd 40 collects excess dirt again, wouldn't it be a problem again? I know how the lining spray has rust and dirt removal feature [/ QUOTE] Lint spray & nbsp; It is used for cleaning lubricated parts. Its main purpose is to clean the brake disc from oils and other lubricants and increase friction. WD 40 is both rust remover and lubricant, meaning it prevents oxidation again while cleaning the rusty surface. /smiley1.gif "border =" 0 "alt =" Smile "title =" Smile "/> & nbsp; I applied it to the battery terminals. It is unnecessary to apply grease oil per battery pole. [/ QUOTE] brother you grew up before us again. [/ QUOTE] < br> |
| 08.05.2020 16:32 | # 9 |
Replace the switch under the hand brake & nbsp; the problem will be corrected. This problem is happening in the 406s.
| 08.05.2020 16:32 | # 10 |
friends center upper hydrolysis tank sensor defective tank complete changing is easy as 90tl
| 08.05.2020 16:32 | # 11 |
I found my 206 flashing cycle problem by replacing the oil dispenser and oil filter.
